Question about ASUS WL-AM604G Wireless Router
My laptop connect to wireless modem (asus AM604g) and after 30 - 60 min hang wireless and i must reset my modem to connect again. What is problem thank you.
    Problem Solver:
  • 16 Answers
Please make sure that the router and the not placed need to any electromaganetic source or any heat source. The modem/router should be placed in well ventilated area and if possible on a wooden surface. The wireless hangs becouse the modem/router gets heated up.
Posted on Jul 08, 2010
How to make wireless network secure using Asus WL-AM604G wireless router
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 18, 2010 | ASUS WL-AM604G Wireless Router
How make 192.168.1.1 work to access the router?
Try other IPs then like 10.10.10.1 or 192.168.0.1 or 192.168.2.1
Mar 21, 2010 | ASUS WL-AM604G Wireless Router
Internet connectivity is constantly cutting out. I have to DIAGNOSE CONNECTION PROBLEM get connected again every 20 - 30 mins.
Please do confirm wireless or wired connection. If wireless ,reset wireless modem,install new wireless software (third party) or make sure wireless adapter in good position.
If wired run winsock fix, make sure ur lan cable socket is not loose, or try differnt cable,check windows update or antivirus.
Jan 31, 2010 | Acer Aspire One AOA110-1113 Netbook
HOW TO UPDATE ASUS WL-AM604g Wireless Router Firmware I HAVE THR TRX FILE
1. Download the updated software from the vendor's web-site.
2. Connect your computer with an Ethernet cable, *NOT* via wireless, to the router.
3. Access the router's built-in web-server interface.
4. Navigate through the web-pages to the "update firmware" page.
5. Click "browse", and point to the file on your computer that is the updated software.
6. Click "update".
7. Hopefully, BC Hydro wil NOT cut your AC power while your router is updating.
8. The router will restart.
9. Done.
Dec 14, 2009 | ASUS WL-AM604G Wireless Router
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
ASUS N50V FnF2 stopped working.
Dun worry. I experienced that before.. There is a physical wireless slide switch at the right of the indication light. switch it on first and see if it works.
Aug 07, 2009 | ASUS N50Vn Notebook
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Nov 12, 2008 | ASUS WL-530g Router
Belkin n1 router - wireless light not on - laptop has limited connectivity
If could be that you were unable to reset the router properly. You have to make sure that the router is on while pressing and holding the reset button using a paper clip. the reset button is usually found at the back of the router, then you may have to reconfigure the settings again.
you can also manually access the router page for you to change the settings.
Oct 05, 2008 | Belkin (F5D7230-4) Router (587009)
ASUS WL-AM604G Wireless Router Logo
294 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
