Question about Sharp LC-32SB24U 32 in. LCD TV
I have a Sharp LCD 46 TV model LC46LE810UN connected to U-verse DVR by HDMI. When I turn on the TV using Input4, the TV does not get a picture. All I see is the input4 HDMI 490p or 1080i, maybe a h1006 message. I can get a picture by re-boot of the U-verse receiver. I conntacted AT&T and no answer. Thank you, **** Kinney
  • 4,889 Answers
Its a firmware bug in the reciever software. Updating it may resolve the issue. Ask AT&T guys if there is a firmware update available for your receiver.
Posted on Jul 08, 2010
Troubleshooting
using the TV remote access the menu then go to sound settings and turn the speakers back on
Nov 10, 2013 | Sharp LC46LE810UN 46 in. LCD TV
I have just bought 32 inch sharp flat tv. I want to connect the base to the tv but the package did not come with screws or bolts. What type and size of screws or bolts do i need? Where can i buy the screws...
What is the model of this 32" Sharp TV? Some stand is snapped in type.
If they use screw, they will be Metric screws, either M4, or M5 from HD, or LOWE'S, or ACE hardware, about 35 cents each.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Aug 26, 2011 | Sharp LC46LE810UN 46 in. LCD TV
I'm needing a replacement stand for my sharp aquos model LC46LE810UN
The stand and the screws you will need for them can both be purchased at encompass parts.
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEARCH&mres=1&mrpn=SHALC46LE810UN
Jul 18, 2011 | Sharp LC46LE810UN 46 in. LCD TV
I just purchased a sharp lc46le810un and it has no color picture from my Direct TV cable box. I am using yellow red and white cables to connect to the TV. Sharp does not address this issue in there...
Sounds like you may have plugged the cables in the wrong way. We have direct tv and none of ours have the three cables. it uses either a coax or an HDMI cable.
Dec 23, 2010 | Sharp LC46LE810UN 46 in. LCD TV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Logik tv
I just experienced the same issue that is described in the previous post. I went through all of the standard trouble shooting modes.
  • Powered down the LCD
  • Switched HDMI cables
  • Checked and reset all connections (even unrelated devices)
I finally got a picture when I made a straight cable connection. I have a sling box attached through my cable box and noticed that the picture was fine when viewed on my PC. I thought it had to be a problem with the LCD. As a last ditch effort I powered off my DVR box, it must have reset the signal from the cable box to the television because everything is working again. I hope this helps you.
Television: 46" Sharp Aquos (LC-46SB54U)
DVR: Scientific Atlantic Explorer 8240HDC
Feb 01, 2009 | Televison & Video
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No Picture
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-32SB24U 32 in. LCD TV Logo
287 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
