Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Paper mismatch displays on the printer. I have to pick the paper size manually on the printer to print. How do I stop this error?
Paper Mismatch Solution
I've FINALLY fixed this problem. Go into Machine Settings and scroll to and select Auto Continue. I've had this problem with one of our PCs with the printer since we got it. I've just got a new main PC and it started doing it with that. Changed the settings in terms of paper size, etc, didn't make any difference. Then I saw the Auto Continue choice and selected that an now everything prints without having to go to the machine and press the button to over-ride the mismatch error. Thank goodness.
Posted on Aug 04, 2013
Make sure that the paper size of your document, and of the tray are set the same - if there is any conflict you ned to resolve it each time.
Posted on Jan 24, 2011
Solution for error code 005-196
This is essentially a paper size mismatch which causes a paper jam. Technically you submitted a print job for a paper size that did not match the paper which was fed into the printer. Example, your document is legal size but the printer pulled a letter-size paper. As it passes through internal sensors along the paper feed path, the paper size doesn't match the document size (created on the PC) and so the printer stops with the paper in its path posting the error and causing you to have to remove the paper from the jam area. The resolution is either provide the correct size paper based on the document settings in the PC application (may need to be fed in the printer's manual paper tray) or change the document size within the PC application to match the size of the paper being fed into the printer. (Paper size can also be modified in the printer settings on the PC.)
Nov 18, 2014 | Xerox WC7232 Printer
FUJI XEROX DocuPrint M205 b - printer error - paper size mismatch
i just bought a FUJI XEROX M250b and it keeps displaying paper size mismatch not allowing me to do any printing or use other application. ive read the manual over and over and i cant fix this problem. Anyone have any idea how to fix this?
Apr 20, 2011 | Office Equipment & Supplies
I am trying to print invitations size 5.5 by 8.5 on my HP Puotosmart C5580 printer and I am having a problem. It keeps telling me that I have the incorrect paper. Would you please advise? Thanks
Go to HP Solution Center
Click Printer Settings
Click Printer Preferrences
Go to Paper Size
Look for the size of your media or
choosee Custom
Then type the width and length of the paper
then save it
change paper type to plain paper
then got to Printers under control panel of your PC
right cick on the printer icon then choose printer properties
click printer preferences
got to features tab
Go to Paper Size
choosee Custom
then save it
then try printing again
you can also refer to the link below for additional info
'Paper Mismatch,' or 'Paper Size Mismatch' Error Message Displays When Printing in Microsoft Word
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01824353&cc=us&lc=en&dlc=en&product=3575276&tmp_track_link=ot_search
'Paper size mismatch' Message Displays on the HP Photosmart Printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01631553&cc=us&lc=en&dlc=en&product=3575276&tmp_track_link=ot_search
Hope I help you a bit.
You can also send me questions on my
personal email - christian4122@yahoo
Your's Truly,
Christian from HP
Mar 27, 2011 | HP Photosmart C5580 All-In-One InkJet...
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
I got around this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 25, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper size mismatch - c5280 hp all-in-one printer
I got around this problem by tricking the printer. The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job. What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job. Here is the tricky part... one the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11 I hope this helps.
Deny When the 8.5x11
Jun 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer keeps printing garbage
i believe that if you update the firmware for the copier, you shoud see that the garbage printing should go away.
Mar 31, 2009 | Minolta DiALTA Di183 Copier
Konica Minolta paper mismatch problem
make sure that you specify the same paper size in the print dialogue window - i.e., in MSWord go file - print - properties - and make sure paper size in the dialogue box matches media type in printer tray
Mar 20, 2009 | Konica Minolta magicolor 5430 DL Laser...
Paper Mismatch
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
Mar 11, 2009 | HP DeskJet 5550 InkJet Printer
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
1,624 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
