Question about Venom Micro Rescue Helicopter Ready To Fly
My boys have a venom micro troop transporter helicopter, serial #2650915228A. Lately, when the copter is more than 8 feet from the controller the copter dies. Is there any way to increase the range? Thank you, Jason
  • 748 Answers
Hi
The range itself is configured in the electronics and controlled by the FCC. The most common problem here is the transmitter batteries are weakening or are those clone type batteries. If you can find them, Fuji makes the best batteries for RC electronics. Good luck
Posted on Jul 08, 2010
Controler wont control the copter the blue light is blinking on the helicopter and the red ligher on the controler is blinking aso. This happend after a crash
Make and model would help a lot here, but many of the controllers on the small remote control helicopters need to be reset after a crash disconnects the link. You do this by turning both the helicopter and the controller off, then turn the 'copter on first and the controller second. When the lights on the 'copter indicate a connection, take the power control lever on the controller and push it first all the way up, and then all the way down. This resets the controller and should enable the link again.
Mar 14, 2015 | Toys
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
We haven't used the helicopter in awhile and we have forgot how to charge it, were should all the switches be ?
Are there electrical contacts on the bottom of the helicopter?
See if there is a place on the remote where you can attach the copter. Use the remotes' batteries to charge the copters' built-in, non removable battery.
Also... Google.
Jul 08, 2014 | Night Hunter Xtreme Glow In The Dark RC...
Nemisis battle copters on same channel
I just fixed this problem on mine. The helicopters are not actually set on channel A. Not sure why it says that on the bottom. They match the channel on the controller.
Here is how:
-First turn one helicopter on
-On one of the controllers select channel "C"
-Move the throttle stick(on left) all the way down
-Turn the controller on
-Move the throttle stick all the way up and then back down again
-When the light goes from blinking green to solid green that copter is ready
-Repeat this with the other copter but select channel "B" or "A" instead
For some reason it works better when you start with the higher channel, C, first and then work your way down.
Hope this helps!
Jan 08, 2013 | Toys
My micro x copter tou3253 will not gain enough speed to lift off why?
are the 2 above stupid ! as if someone wud not clear any hair out
Jan 07, 2012 | RC Micro X Copter Mini RC Helicopter
Can't figure out how to change frequency on the S107 copter itself (not the controller). Can someone advise. Thx
Found this for you.
it appears that the helicopter dynamically configures the control channel upon first detection of a signal from a controller. So, If you 1) turn off the helicopter, then 2) turn on the controller, then 3) select the desired channel on the controller, then 4) turn the helicopter back on, then 5) hold the throttle down on the controller, the helicopter will start up (after a slight delay) and be controlled via the new channel.
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Radio...
My helicopter flew for a few seconds and then feel to the ground. It seems as if the controller does not work with the helicopter
Check your battery pack to see if the controller lost power or the battery pack in the RC ARF to ensure that, the copter can receive.
Dec 22, 2010 | RC ARF Falcon 40 Helicopter
Venom Micro Rescue Helicopter Ready To Fly Logo
351 people viewed this question
Top Venom Toys Experts
ray gallant
Are you a Venom Toy Expert? Answer questions, earn points and help others
