Question about Vacuums
The Vax carpet cleaner does not suck the water up off the floor
SOURCE: hoover will not suck carpet shampooer
no solution, hoover is by far the most rediculous machinery... it says its as easy as filling it up and using it as a vacuum.. but it doesnt show how the hell you fill it up, there are two possible places where water and solution obviously enters and leaves... yet niether of them open up for fluids to be put in
and of course the instructions dont tell you how to fill it up
no wonder it has only a 30 day money back "guarentee"
because it takes 30 days for the buyer to realize that it doesnt work
so you can spend 300 on this faulty product.. or spend 300 on something that wont infieriate you
have fun
Posted on Jul 24, 2008
SOURCE: The bissell proheat turbo carpet
Bissell cleaner will not **** up water???
Posted on Sep 14, 2008
farr64
  • 121 Answers
SOURCE: Cleaner not sucking up dirty water.
try stripping it down and cleaning all parts and filters .some cleaners use a safety 'ball' to stop water getting on the motor is this stuck it should slide up and down a small track in a tube..good luck hope this helps farr64.
Posted on Apr 29, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 25 Answers
SOURCE: Bissell carpet cleaner not sucking up.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Posted on Apr 24, 2010
Rapide XL. Why isn't it sucking up the dirty water?
you need to set it lower for water
Aug 10, 2015 | Vax Vacuums
Vax vrs5w will not suck up dirty warter
sounds like the filter is clogged.
Who makes this dirt sucker?
Aug 19, 2014 | Vacuums
Carpet cleaner vax
did it work before? if so then you could have a blockage from the outlet (where the pipe connects to the water tank which model do you have ? and was the filter present when you was working with the trigger only?
Apr 15, 2014 | Vacuums
Oreck carpet cleaner wont **** up water
Your reservoir is full. Empty the water and it will work properly.
Feb 20, 2013 | Oreck XL Shield Power Scrubber Floor And...
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
My Vax rapide is not sucking up water?
I had the same problem. Then I took off the brushbar (it's underneath at the front). It just pops off. Then it worked fine. I guess you only need it for long carpets.
Jul 02, 2009 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Jun 07, 2009 | Dirt Devil CE5500 Floor Keeper Upright...
Open Questions:
Vacuums Logo
160 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
