Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
Water sits in bottom of dishwasher and does not drain
    Novelist:
  • 160 Answers
If you have recently installed a garbage disposal the knock out the plug in it where the dishwasher drain connects to it. If not it sounds like the pump may be out or your drain line is clogged. Check the drain easiest way is where it connects to the pump disconnect it but make sure you go slow and you put a bowl under to catch the water. If you need any further assistance please contact me back.
Posted on Jul 08, 2010
Water is not draining out of the bottom of the dishwasher and is sitting in the bottom
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 27, 2011 | Maytag Dishwasher
Not draining properly
Check for plugged drain hoses in your dishwasher, also make sure that the pump is working correctly
May 06, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
DIshwasher doesn't drain. 3-4 inches of water sits in the bottom
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Sep 25, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher did not drain all the water - water sitting in bottom of dishwasher
start and cancel cycle to drain the water out and check the position of your drain hose.....water is probably backwashing into the d/w, hose should leave the drain and go up to the height of the d/w
Jun 10, 2009 | Dishwashers
Water not draining from dishwasher
1.attache the drain hose to the bottom of contertop.
2. drain back valve is not work properly.
Dec 20, 2008 | Whirlpool Dishwashers
Water sitting on the bottom of the dishwasher
disconnect it from you drain and put it into a bucket. Then start a program and then cancel it, the begining should start with a drain anyway. Then you will see if any water comes out. You can also take a shop vac after to get the water out to see if there is any stuck there.
Sgt 48
Apr 25, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
162 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
