Question about Visual Land VNet VL760 Netbook
On the VL760, when I plug in a thumb drive in the rear USB, nothing happens.
The netbook will do nothing w/the drive if it is larger than 4Gb. i believe same holds true for the SD card reader.
Posted on Aug 24, 2010
Use thumb drive
Go to the SanDisk website
you will find product support there
Dec 08, 2015 | SanDisk Electronics - Others
Device is prompting me to erase bd data usb device (rear)
Do you happen to have a usb thumb drive connected when you get the message? What, if anything is plugged into the usb port?
Dec 03, 2013 | Sony BDP-S590 Blu-ray Disc Player BDPS590
I have v760 with windows CE I forgot my password How to remove this option
As you forgot Windows password, you can create a bootable DISK (CD/DVD or USB flash drive) for Windows password recovery on your own, i ever created a bootable USB flash drive with the tool Windows Password Breaker and reset my administrator password successfully.
Jun 22, 2011 | Visual Land VNet VL760 Netbook
I have a Dane-Elec 4gb thumb drive. First one i bought worked for a while then kept saying error. so i returnd it .. got a new one, and now it wont open anything at all or even register that its in there. ...
Try connecting it to a different computer.
If it still does not work, take it back, and get the store to verify that it works,
by plugging it into one of their "demonstration" computers,
or get them to replace it.
Oct 15, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
I plug it in and nothing happens. Its brand new
When you plug it into your usb , goto My Computer , in the list of drives there should be a drive in relation to your usb drive.
copy your tunes and paste them right in there.
hope this helps
Dec 04, 2009 | Verbatim VER95327 USB Hard Drive
Plug in my hard drive and nothing happens
Make sure that your usb hard drive is inserted properly into the computer but if nothing happens, go to your bios settings of your computer and be sure that usb function is set to on. Save changes and restart the computer. If you dont know how to do this, first turn on the computer and press the delete key in the keyboard, once you enter the bios screen look for the usb settings and make sure it is set to on. Hope this could help. Thanks
Oct 23, 2009 | Computers & Internet
Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
Oct 20, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Acer 3100 laptop running windows xp, my USB ports are not working
No my repair shop see's this alot. All my employee's use thumb drives religously in our shop. I see this happen often esp if it gets used alot. I have even seen this happen when its removed while shutting down the PC. It is possible to attempt to reformat the thumb drive. If you unsuccessful, get a new thumb drive.
May 16, 2009 | Acer Aspire 3100-1405 Notebook
Usb ports do not active
One of the great features of USB devices is they can get power from the USB port. Plug in a thumb drive and it just works. The power for operating the thumb drive comes from the USB port. This works for small devices like a thumb drive but not something big like a scanner. The scanner need its own power supply.
There could be several explinations for what you are seeing. Could be you are plugging in a device which is sucking too much power and the laptop is shutting it down. I would test the port with something small like a thumb drive and see if it works. If the thumb drive works but the other device does not a couple of things could be going on. Maybe the device just need power - is there a way to plug in a power supply? Or maybe the device is broken and shorted out. Does the device work on another computer?
If something like a thumb drive does not work then it is a problem with the motherboard. Could be the USB ports are bad. It happens and there usually is no easy fix short or replacing the motherboard ($$$). Occasionally there is a BIOS setting for the USB ports. A bit of a long shot but worth a look.
A possible work around would be to get a power USB hub. A hub plugs into a USB port and provides 4 or 7 USB ports. Good ones come with a power supply. When the hub is plugged into the power supply it does not draw power from the computer. Might solve your problem.
Aug 23, 2008 | Acer Computers & Internet
HELP ME ASAP! camera problems uploding pictures
I never use the computer hook-up programs/equipment that
come with a camera.
What you should try is a Card Reader Thumb Drive.
I recently bought one for SD cards at Office Max for about $12.
All you do is remove the card from your camera, insert it in the
thumb drive, plug the drive into a USB port, and take it from there.
A window will open up on your computer showing a folder named something like "DCIM". Just double-click on this folder
and you'll see a list of the pictures on the card.
Mar 06, 2008 | Canon PowerShot A430 Digital Camera
Visual Land VNet VL760 Netbook Logo
46 people viewed this question
Top Visual Computers & Internet Experts
Andrew Taylor
Andrew Taylor
Lawrence Oravetz
Are you a Visual Computer and Internet Expert? Answer questions, earn points and help others
