Our Samsung Smart Inverter model # AQV09JAX keeps sutting off
  • 3,083 Answers
I'm having trouble reading .pdf files on my computer, but I found one file relavent to your model:
www.acwholesalers.com/.../samsung%20aqv09%20aqv12%20service%20manual.pdf
You might see what they say, and if they can give you a clue. This unit will shut off when freon is low, or the compressor is failing, the control board is bad, causing the relay to fail, or a bad relay.
There are many blogs on the net explaining how to troubleshoot a failure like this. Here's a good site that explains maintenance, and what goes wrong and why:
http://www.familyhandyman.com/DIY-Projects/Indoor-Projects/Kitchens/Kitchen-Appliances/how-to-avoid-refrigerator-repairs
Good luck, and hope this helps
Posted on Jul 08, 2010
Samsung smart tv UN 55ES 6100F Black screen audio ok
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | Samsung Televison & Video
60 samsung led smart tv cant adjust brightness
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 14, 2016 | Samsung Televison & Video
I have a samsung led smart tv 50 inch model UA50F6300AMXXY we have sound but no picture. when you shine a torch to the screen you can see images, any idea what the problem could be? Thanks
The inverter board that is used for led powering has failed or some of its connection isnt good. That is the reason that you can see picture but the panel doesnt light up. Try finding am inverter board for the specific model or send it back for repair claiming that it is their device malfunction.
Oct 21, 2016 | Samsung Televison & Video
My Samsung smart tv has sound but no picture
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 25, 2016 | Samsung 5500 Series UN32F5500AF 32" LED...
Samsung smart tv has a black screen that flashes to a real screen for about 1 second then goes back to black. it has sound
http://electro-medical.blogspot.com/
Mar 13, 2016 | Samsung 5500 Series UN32F5500AF 32" LED...
Samsung 50 Smart TV...Sound but no picture...Fuse? or Inverter? or what?
Look at the picture up close and with a flash light. If you can see images then it is the inverter
Sep 09, 2015 | Samsung Televison & Video
Why does my Samsung model UN32H5203AFXZA have sound but no screen is black?
http://electronicshelponline.blogspot.com/.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 27, 2015 | Samsung 32" Black LED 1080P Smart HDTV -...
How to replace the backlight inverter board on Samsung smart tv UN55ES6100F?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jul 03, 2015 | Samsung Televison & Video
Samsung tv keeps turning it self of
You don't indicate model number or age of your samsung tv, although it's very likely you may find swollen tops on one or more electrolytic capacitors on the power/inverter module. The tops of the caps may bulge like those i've pictured. You will need soldering skills to replace these parts. Value and polarity are very important while replacing electrolytics. 3_5_2013_2_45_30_pm.jpg
Mar 05, 2013 | Samsung Televison & Video
I need an operation manual for an AQV09JAX split
Try with following:
www.samsung.com/in/consumer/.../air-conditioner/index.idx?..
Dec 08, 2010 | Samsung Heating & Cooling
Heating & Cooling Logo
387 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
