Question about Philips 43P8341 43" Rear Projection Television
Philips 46 in rear projection tv has too much green. The bulbs are good but adjusting the color does not help.
  • 62 Answers
This models have coolent issues. I would tke off the front screen very carefully , as it may seperate , get a friend . Do not scrach the screen. then look down inside the units CRT's (Cathode Ray Tube) and see if its cloudy or fuzzy looking . While there look at the blue tube as well. If its fuzzy replace the coolent.
Posted on Jul 08, 2010
I have a 46" magnavox projection screen tv that has the red, blue, green colors on the left side of the screen when first turned on. After a few minutes of being on, the screen resumes to normal colors. ...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Philips 60PP9352 60" Rear Projection...
How much for a bulb for a 46'' Rear Projection Tv? It only has red and green need a blue bulb.
Anywhere from $100.00 up to $500.00 depends on New or used but good. On these TV it usallly needs New projection fliuld ,Blue is always one to fill with new fluild.look down into top of tube if it is not clear fliud is bad.
Sep 18, 2009 | Philips Televison & Video
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Philips Projection TV Bulbs need changing
Buy a new television. The "bulbs" are actually small picture tubes, also referred to as CRT's or guns. There are three of them, Red, Green and Blue. The cost for the tubes alone will probably exceed the original purchase price of the television. If the new tubes do not have the lens assembly attached, then you will need to transfer the old ones. This involves draining, cleaning, and refilling the coolant chambers. Once installed in the set, there is a series of mechanical and electrical adjustments required, to get the picture aligned or converged. This procedure is not recommended for the inexperienced. If cost and time are not an issue, then everything can probably be found on the Internet. Simply search the web for your model number. You will need the remainder of the model number first. There are at least eight models starting with 46PP9302. You are missing three additional characters.
Discouraged yet?
Nov 15, 2008 | Philips 46PP9302 46" Rear Projection...
Philips Rear Projection Issue with Color Alignment.
this seems to be convergence problem in your tv .............
Aug 23, 2008 | Televison & Video
46 inch rear projection tv
The convergence modules are bad. They are made by SDK. ShopJImmy has them. Buy the kit because it has resistors and fuses that you may need to replace too. TV Parts Universal TV Stands DLP Chips ShopJimmy
May 23, 2017 | Hitachi 55FX48B 55" Rear Projection...
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
Philips 43P8341 43" Rear Projection Television Logo
93 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
