Question about Karcher 2500 PSI Pressure Washer
Pressure starts and stops
When I start to pressure wash it holds pressure for a few seconds and then cuts out. I have plenty of water going to the unit--there are no kinks in the line etc....It just pressures up, the engine revs, and then it cuts out. After a second or two it pressures up again. Thoughts?
    Problem Solver:
  • 13 Answers
Sounds like your unloader valve is sticking. It needs to be removed and lubed with lithium grease.
Posted on Jul 16, 2010
We are trying to start our power washer and it won't start. what should we try
clean carb
If it runs for a few seconds when you spray some carb cleaner in the intake, then you know you have spark. Clean your carb and it should be good to go. If you do not have a fuel cut off valve in your fuel line you can save a whole lot of trouble by installing one. Then when you are done pressure washing , close the fuel cut off valve and continue spraying water until the engine stops. That empties the carb bowl. Your carb remains nice and clean until you are ready to use it again in six months.
Sep 27, 2014 | Garden
How do I start the engine after it sits for a few months? No it just can not start.
clean carburetor
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
I have a gulf stream pool heat pump. It tries to start and runs for a few seconds then shuts down. it will do this like 3 times then stops. will repeat about every 10 minutes. was working find 2 days...
Hi, sounds as though you may have several problems, or I should say there are several things that will cause a unit to short cycle and then shut down. First of all, the head pressure in the system if it is getting to high, will cause this unit to shut off on its high pressure switch. When it shuts off the pressure will drop and the switch will reset on auto and start again just to do the same again. Shut the power off to this unit. Take a water hose and give the coil that surrounds the condenser a good washing out. Be careful not to bend the fins down on it as this will prevent air from being released to the outside air. Use a nozzle and adjust it as needed. If the problem was a head pressure problem, this will stop it from short cycling. If I were on site with my manifold gauges, I would no right away if it was a head pressure problem. After doing this, if it starts to do the same thing again, being low on freon will also cause a system to short cycle. If it was fine 2 days ago, I doubt if it is low on charge. Make sure the outdoor fan is up and running as this will cause it to go off on high pressure cut-out. This does sound like your problem. What happens is the coil gets dirty over time and the air can't be removed properly. The compressor will start and the pressures will rise very fast and shut of with in a few seconds. After a few attempts to run, the compressor will lock out on internal overload until it cools off and resets its self. It may take 5 to 30 minutes for it to start and try again. Do the cleaning process I have asked not getting water directly into the electrical control panel, but give this coil a good washing. If this system has a return air filter somewhere, make sure it is clean. Do this and get back to me and let me no if this solved or helped at all. If not, we can go from there. Just look me up with my user name. I do believe its just a plugged condenser coil. The symptoms are as you describe to me. Please get back to me.
I hope the best to you,
Shastalaker7
Apr 10, 2010 | Heating & Cooling
After about 10 mins error code H2O is displayed.
the h2o message means the machine isn't getting enough water. check pressure and water intake pipe.
Mar 15, 2009 | Washing Machines
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Home water well problem
Two things maybe. Are you sure the air is coming out? Not in? If its after the pump stops and then stops after a while it may water rising back up into the sleeve after the pump stops. If you can hear it while the pump is running then maybe its the opposite. Hold a flame near the sound tho see which way the air is going.
Feb 27, 2008 | Washing Machines
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
Jul 24, 2007 | Maytag Neptune Washer
Karcher 2500 PSI Pressure Washer Logo
383 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
