Question about Weather King 10AJA4201AH Air Conditioner
Fan stopped working
Compressor is working but fan has stopped
    Scholar:
  • 80 Answers
Try to turn the fan by use of a long screw driver or other object. If it feels like it is siezed or getting very hard to move then the fan motor needs replaced. If it turns freely I would replace the capacitor and if that does not solve it then replace the fan motor too! Capacitors are cheap and fan motors are $80 to $120 average!
Posted on Aug 29, 2010
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
My samsung refrigerator is 4 and 1/2 years old, the fan started making noise and the inside walls of the regrigerator and freezer were hot. one night it stopped working and there is no activity on the...
replace the compressor fan when it stops working the lines heat up also unplug your unit if it keeps running without the fan you will do damage to your compressor i suppose if you had no wear else to keep your food you would use a large portable fan to blow on the compressor bulb this is not a permanent fix and may only work till you get the new fan if you have any further questions message me back and please rememeber to rank how this opinion has helped thanks Rick
Jan 29, 2011 | Samsung Refrigerators
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
The gasket around my refrigerator is too hot to touch, what is wrong?
turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
Jun 07, 2010 | Whirlpool Refrigerators
Cabinet flanges and mullion very hot to the touch and not cooling at all, model ed25qf
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compressor works but compressor fan does not
It is possible the capacitor has gone bad, cause, possibly a power surge. Suggest replacing capacitor first and see if problem happens again then I would change fan motor and capacitor. Good luck on your repairs
Dave
Dec 07, 2009 | Heating & Cooling
Compressor won't kick off
What happens when started in just fan mode? Sounds like relay stuck.
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Apr 22, 2009 | Kenmore Refrigerators
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Weather King 10AJA4201AH Air Conditioner Logo
161 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
