Question about Efficient Networks SpeedStream 5200 Modem
My speedstream 5500 act as a swith now,the led light normal, I think i need the firmware to save it. Please help.
  • 493 Answers
You can find the information and the firmware that you need in this link.
Hope this helps.
Kind Regards.
Posted on Jul 08, 2010
  • dimzhu Jul 08, 2010
    WriteDiv();fDisplayMenu();
    5500
    Home
    Reboot
    System Summary
    System Type:
    SpeedStream 5500-Series
    if (0) {document.write("Original Config:");document.write("");document.write("Upgrade Count:");document.write("0");}
    Config Part #:
    003-3015-INT
    Firmware Part #:
    004-E540-A09
    MAC Address:
    00:20:EA:FD:78:7E
    if (bShowPPP) {document.write("
    ");document.write("");document.write(" Point to Point Connection Summary:");document.write("");document.write("");}
     ");}if (bShowrfc2684) {document.write("");document.write("");document.write(" RFC2684 Connection Summary:");document.write("");document.write("");}
    2684(0) 0/35
    Not Trained
    2684(1) 8/35
    Not Trained
    2684(2) 0/43
    Not Trained
    2684(3) 8/43
    Not Trained
    2684(4) 0/51
    Not Trained
    2684(5) 8/51
    Not Trained
    2684(6) 0/59
    Not Trained
    2684(7) 8/59
    Not Trained
Gu10 led light bulb are energy saving led Bulbs
Yes Gu10 led bulbs are energy saving led bulbs please check out the link below to know more about how much Gu10 led bulbs save energy
SHEERLED LED Bulbs SPOTLIGHT IN UK GU10 LED Lights IN UK
Sep 08, 2015 | brianydeal 3w Gu10 16 Color Rgb Led Light...
Harley charging LED indicator does not light
light off means it is charging I would say , light on means n charge.
Mar 12, 2014 | Harley Davidson Motorcycles
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens Speedstream 4200 NetComm V300 on VOIP
When the V300 Line/Phone led flash in alternating fashion, it's telling you it's WAN connection is dead. The WAN light is off too. so internet and VoiP phone will not work
When the V300 Line/Phone led flash in sync, it can't register to the SIP server.
The V300 does not appear to be listed on the Mynetfone website though. Have you checked to see that your V300 has the latest Firmware. LINK
It may be that the V300 is not getting it's IP renewed. Can you alter the IP lease time? Do you have the V300 set up for PPPoE, or do you have it set to static or DHCP (refer CH4, page 25)
Jul 01, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Siemens SpeedStream 6520 Wireless problems! please help
um not sure, but if you have the disk that came with your router run it and fill in the wireless wizard. Also, on my 6520 the "wireless" led doesnt light up unless i have a device connected that is wireless. Your laptop may be incorrectly setup
Jun 25, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 6520 enabling voip connection to yahoo voice
Dear yohwayne
I am afraid that there are incompatibilities between speedstream 6520 and Voip service. I will need to look at this a little bit further but I think the only workaround is a firmware update. (modified version of the original)
Regards
EngineerGR
Apr 29, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Efficient Networks SpeedStream 5200 Modem Logo
53 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
