Condensation in the furnace, as a result of which air is not being circulated. Air conditioner is Carrier Model#38CKC036340. Is there any place where I should be removing the condensed water??
  • 456 Answers
The coil for the AC sits above the furnace. Two refrigerant lines enter the
plenum, usually the condensate line is on the same side and at the bottom of the plenum. Sometimes they use pvc pipe or a garden hose to drain the condensate.
Your problem is worse than that, it sounds like your indoor coil is froze up, that is why you dont have airflow, either you have a dirty filter or your fan does not work
Posted on Jul 09, 2010
How to properly install my carrier siesta air conditioner,seems to build up condensation that wont evaporate ,justwant the proper installation diagram ,orhow to do it yourself kinda video
condensation doesn't evaporate
it runs off the evaporator fins into a drain channel and out side
it is possible that the drain is blocked
the action of an air conditioner is to remove the humidity (condensation from the room) and drain it outside
if it is to evaporate then the purpose of the air conditioner would be defeated.
Jun 30, 2015 | Carrier Siesta II TCA101B Air Conditioner
Need to find out type of refrigerant a 38ckc036340 uses
Hi Mate,
Just wondering if you have refrigerant currently in the system? It looks like it is to be charged with puron refrigerant which is the trade mark name for R410A.
Dec 19, 2012 | Carrier 38CKC036 Air Conditioner
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
Im looking for the specs on a Carrier air conditioning unit model no. 38ckc036340
here ya go
www.xpedio.carrier.com/idc/groups/public/documents/.../38ckc-c2w.pdf
Jun 21, 2010 | Carrier 38CKC036 Air Conditioner
Furnace not blowing air
this may sound not useful but the first thing to try is turn off the breaker or fuse to the feed for the furnace for 1 minute and turn back on and listen and note exactly what it does from there and will have better idea how to help and this might fix the problem try and let me know th results
Dec 31, 2008 | Carrier 38CKC042 Air Conditioner
I am living in a home with a carrier furnace. The furnace is in the back part of the house in a store room. It has two- 2 1/2 inch plastic pipes. One that suppplies air to the furnace and the other is...
As long as the fresh air intake pipe to the furnace is not plugged up the second vent is not needed some homes when they are new are air tight and need a fresh air circulation system
Oct 30, 2008 | Carrier Heating & Cooling
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38CKC030348 air conditioner
If the capacitor is bad replacing it is just a mater of moving the wires from the old one to the new one and mount the new capacitor securely in place. In replacing a capacitor it is recommended to replace it with the same rating as the one removed.
If the capacitor is bad it will not prevent the compressor from getting power. Is the compressor trying to start at all. If the compressor is running and you have no cooling the system could have lost the charge of refrigerant.
Jul 02, 2008 | Carrier 38CKC036 Air Conditioner
Model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
222 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
