Question about Vacuums
How do I unclog a bissell vaccum? I'm not just talking about unclogging the hose, I need to unclog the complete vacuum cleaner. HELP!!!
  • 328 Answers
Well firstly, whats the model number and do you have the user manual to hand?
If the main hose has been unblocked, then it could be the main dirt channel which is blocked just after the moving roller brush panel. A long pipe cleaner or wire brush can remove this blockage easily rather than taking everything apart.
Posted on Apr 19, 2008
How to unclog a bissell proheat pet carpet cleaner
There are a few at home remedies you can try. White vinegar can be used to disinfect and unclog the cleaner. I would suggest running it through a few times. However if that doesn't work, there are supplies you can buy to unclog the carpet cleaner.
Elisa Jed ' http://www.missionimpossiblecleaning.com.au/services/
Jun 27, 2014 | Vacuums
How to unclog a bissell proheat clearview carpet cleaner?
Check your User's Guide for filter locations. Bissell Consumer Care 1-800-237-7691
Jun 23, 2014 | Bissell 1699 ProHeat Clear View Upright...
The handle hose on my bissel proheat turbo 2x is clogged, how do I unclog it?
Try suctioning clean water from a sink or bucket with the attachment removed from the hose. If the attachment is clogged, soak in hot tap water for 30 minutes and clean the end with an old toothbrush.
Here's a link to locate a BISSELL Authorized Service Center if you continue to have problems.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 10, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to unclog a bissell proheat turbo carpet cleaner
proheat 9300
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Nov 24, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Suction not working well. how do I unclog?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Nov 27, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
How do you unclog a hose on a Bissell proheat powerlifter
Detach the hose completely.
Plug wrong end of hose into in port of vacuum.
Turn on. This should remove the clog.
If not, try using a vacuum with an exhaust blower to blow out the clog. Most canisters have these. An air pressure hose may work as well.
Nov 23, 2010 | Vacuums
Bissell proheat turbo sprays water but does not spray the cleaning solution. How do I unclog it?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rsttsr
Jun 14, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hose that releases the water and cleaner on my Hoover is clogged
Your right the hose is clogged.. Use a portable vacuum to blow the dirt inside the hose.
Jul 24, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
The dirtlifter powerbrush do not trun.the belt are ok and i unplug it and trun it back . still not working
I have a Bissell Dirtlifter Powerbrush that will not spray soap. I assume the soap lines are clogged, but how in the heck to you "unclog" them? I've searched high and low on the Internet looking for that answer.......
Apr 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
543 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
