Question about Polaris Pb4 - 60 Booster Pump
Polaris PB4 pool cleaner pump. The pump motor had power but was not turning. I spun the exposed shaft of the motor with my finger and its been running now since yesterday. Is it possible the pump was bound up, or is this an indication the motor is getting weak? Does the motor have thermal protection to prevent the motor from overheating?
    Top Expert:
  • Polaris Master
  • 5,922 Answers
Bad start up capacitor replace or replace pump
Posted on May 22, 2016
SOURCE: my polaris PB4-60 booster pump does not turn over.
I was able to save a service call by doing the following in under 8 minutes:
1.Switch off electric to pump.
2. Turn off valve on supply side of pump so water does not flow during this procedure.
3. Turn offf filter.
4. Unbolt the six bolts (1/2" socket) on the front side of the pump.
5. Carefully separate the pump from the front panel which contained the six bolts.
6. Grasp with both hands the black round thin disk (impeller) which is part of the pump and turn it either clockwise or counter clockwise. It may be slightly difficult initially but once it it freed it will move easily.
7. Reassemble.
8. Open valve and turn on filter and the power to booster pump.
Any questions e-mail me at bbgreg@optonline.net good luck
Posted on May 31, 2009
john224
  • 1378 Answers
SOURCE: polaris booster pump overheats and trips the breaker
The motor may be repairable. Check with local electric motor repair shops in your area. The motor may need to be replaced though and if so, we sell it at www.arrowmotor.net
Posted on Jun 14, 2009
Coastsider
  • 331 Answers
SOURCE: Just bought a new polaris booster pump (PB4-60)
Have you checked for voltage at the pump motor? Did you wire it correctly? Is the motor 110V or 220V. Did you match the motor to your existing voltage?
Posted on Apr 14, 2010
MOTORWIZJ
  • 1358 Answers
SOURCE: How do you change the shaft seal on a polaris
BE CAREFUL YOU CAN BREAK THE SEAL PLATE BY OVER INSTALLING THE #1000 SEAL , TAKE 6 BOLTS OUT UNSCREW IMPELLER THE TAKE THE 4 BOLTS THAT HOLD THE SEAL PLATE TO THE MOTOR, KNOCK OUT OLD SEAL FROM SEAL PLATE USE SOCKET THAT FIT OVER SEAL. I USE A 1 1/4 SOCKET. THEN REPLACE CERAMIC IN IMPELLER (READ INSTRUCTIONS WITH SEAL) OR TAKE IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY.. HAVE HIM DO IT . $ AROUND 40.00
Posted on May 24, 2010
john224
  • 1378 Answers
SOURCE: I have a problem with my Polaris pump PB4-60. The
Thank you for posting your question here on Fixya.com.
As those pumps wear the impeller ends up rubbing against the flange gasket (if present - depends on the age of the pump) and will eventually cause enough damage that the pump will quit pumping. Open the pump up and replace the impeller, gasket or o-ring, and seal if they are at all worn and your unit will be good as new. You can find a parts print here. If you are not familiar with these repairs a local electric motor or pump repair shop should be able to do them for you for under $100 parts and labor.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 01, 2011
Are there any other booster pumps that I can use to run my pool cleaner? I had a Polaris bp4-60 for 7 years, it finally failed. Replaced it with same model. Ran for few mins then shuts off then restarts....
I think Polaris should refund the purchase price on these pumps. I changed the breaker, the whip, and upgraded the outlet (using 110). The dealer exchanged it for me, but would not give me a refund, and I had the same issue with the second motor. I used a Hayward 6060 pump as a replacement. Everything works fine.
Jul 04, 2014 | Polaris Pb4 - 60 Booster Pump
Pump pb4-60will not run
if voltage to it and filter pump running see if shaft turns maybe bad capacitor or motor
Oct 04, 2013 | Polaris Pb4 - 60 Booster Pump
Pb4 booster pump is trying to engage. It has a humming noise every 10 to 15 minutes but will not engage
turn off try spinning the back shaft of motor then try if still doesn't work need new pump or motor
Sep 01, 2013 | Polaris Pb4 - 60 Booster Pump
Polaris Booster Pump PB4-60 Overheating
see side of motor make sure wiring correct if ok maybe you got a bad one
Aug 29, 2012 | Polaris Pb4 - 60 Booster Pump
Pump seems to start ok - 240 volts - shaft spins but not enough water pressure to move the polaris cleaner?
It sounds like you could have some debris stuck in the impeller on this pump. This is a common problem and anything that gets past the pool filter can end up stuck in this pump.
Sep 03, 2011 | Polaris Pb4 - 60 Booster Pump
My Polaris PB4 pump has always made more noise than the main pool pump. now it makes a high pitched sound. i took the pump apart and greased the shaft but this was unsuccessful. after reinstalling i...
The motor manufacturers do not offer cut-away or parts diagrams. Parts such as bearings are purchased thru power transmission outlets locally. Parts for the pump should be found at a local pool store that sells the equipment. You will likely need a new set of 203 bearings, a flange gasket and mechanical seal. All told, the parts should be less than $40.
John
Jan 28, 2011 | Polaris Pb4 - 60 Booster Pump
The pump seems to be running but the water is not coming through with any increased pressure, therefore the cleaner is not being propelled within the pool. What could cause the pump to suddenly lose...
You have spun the center out of the impeller. Get a new impelleer at your pool supply place. While you have the pump open, replace the seals as well.
Jul 20, 2010 | Polaris Pb4 - 60 Booster Pump
How do you change the shaft seal on a polaris pb4-60 pump?
May 24, 2010 | Polaris Pb4 - 60 Booster Pump
Booster pump cracked
Lock the end of the shaft opposite the pump and then turn of the impeller counter clockwise looking at the pump. The remainder is simple nuts and bolts.
Aug 29, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
153 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
