Question about Friedrich WY10B33 Air Conditioner
Doesn't cool. Fan comes on but doesn't kick into
Doesn't cool. Fan comes on but doesn't kick into cooling mode
  • 905 Answers
Hi!
Friedrich publishes all of its manuals, including parts and the service manuals. See below for links:
Serivce Manual 2008-09 Models
Service Manual 2007 Models
Service Manual 2006 Models
Service Manual 2010 Models
Parts Manual Looks like 2009 / 2010 Models per serial number range
Parts Manual 2006 Models
Parts Manual 2007 Models
Owners Manual
All Years
You can find the year model by looking at the serial number. The 2nd letter is the year code. F=2006 G=2007 H=2008 J=2009 K=2010 (there is no "i")
Once you know the year, download the appropriate service manual.
There are troubleshooting guides in the manual that will help you isolate the failed part. You will need a multimeter though in order to check for continuity between switch positions.
I would take a close look at the defrost thermostat first. It is the one component that can disable the compressor in all modes, heating or cooling. It works by sensing the temperature of the evaporator, and if too low, it turns the compressor off, and kicks on a heater. When temperature rises, it turns off the heater and compressor is turned back on. if the defrost t-stat is not able to sense temperature correctly, it may keep the compressor disabled.
Good Luck, post back your results and don't forget to rate!
Posted on Jul 08, 2010
4 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: Fan Works But Unit Can't Start Compressor
Friend,
NGFAM! Happy to assist you!
Sounds like the freon is low therefore it will not or stay on!
My words alone can not help you fix the unit!
You need service!
Let me know how it goes??
Please give me a good rating here at fixya.com before you sign off!
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 29, 2008
  • 251 Answers
SOURCE: Haier air conditioner will not kick on to air
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
mc1bean
  • 3053 Answers
SOURCE: My central air unit comes on but it's not cool and
to me it sounds like filter are dirty, need to be cleaned or replaced, home systems, packaged or otherwise are hermetically sealed and should not need freon recharge. Always start with airflow and/or unit being set too low. An AC unit of any type will build ice if a) the filter is plugged up and can't move enough air, b) it has been run without the filter, clogging the coil, again, not moving enough air, c) setting an AC unit below 68 degrees F will almost ALWAYS cause icing, and d) running a standard AC when it's warm inside and cold outside (unless equipped for "low-ambient operation"). When in doubt, a bit of maintenance(thorough cleaning) by someone with AC skills can cure a b, common sense will cure c d.
Reply
Posted on Jun 23, 2011
Temperature that activates cooling fan
It is usually around 80 deg Celsius.
May 17, 2013 | Honda Motorcycles
Fans only kick on when I run my ac. I replace my coolant sensor still nothing. I have checked the fuses. Where do i go from here?
Sounds like this may be a faulty fan motor, the low speed in these fan assemblys go bad, but the hi speed works when the a/c is turned on. I would check for the cooling fan relay first... you can usually switch this relay with another relay of the same and see if that makes the fan kick on, if it doesn't then i would go with replacing the electric cooling fan motor. Hope this helps
Oct 27, 2012 | 1998 Plymouth Voyager
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
Cooling fan temp light stays on when air condition is on. fans are not kicking on. Is it the fan module ?
I didn't know it had a light on the dash that said "cooling fan temp".
My 93 doesn't.
The cooling fans are controlled by the computer and turned on when the ac is running or when the engine reaches 220 degrees.
A mechanic would check the fuse and relay for power and the fan motor for power and ground.
Aug 26, 2012 | Cadillac DeVille Cars & Trucks
Temperature gage goes up and down
The breather hose should run to the air cleaner housing or intake tube.
Check your radiator cooling fan. If it isn't working the car will run hot at slow speeds or idle then cool down after you get going faster. A quick check would be to turn the AC on and see if the fan comes on. If not try lightly tapping on the cooling fan motor with a wooden broom handle. If it comes on then you have a bad motor.
If the fan comes on with the AC then check to see if the fan comes on after the engine gets hot. If the engine temp doesn't kick it on then the temperature sensor might be bad.
If the fan is ok please post more info on your problem
May 27, 2012 | 2002 Ford ZX2
Why would the cooling fan not be working in a 2005 crown vic CVPI
Does it work when you turn the A/C on? The fan always kicks on with the A/C, if it doesn't look for a blown fuse. Or possibly a fan motor burnt up. If it works with the A/C but doesn't when the engine is too warm, it is probably the temperature sensor.
Feb 09, 2012 | 2005 Ford Crown Victoria
I have a 94 mustang with an electric fan. The fan works perfectly when i start the car and its cold. when the temp of the water gets up to about 185 the fan kicks on . it can idle all day and the fan works...
is the car running hot? some cooling fans never come on going down the road because the air comjng through the front of the vehicle keeps the car cool enough that it doesn't need to come on. but if it is overheating then you may want to check the cooling fan relay.
Jul 19, 2011 | Ford Mustang Cars & Trucks
2005 grandcherokee 4.0 Overheats when idleing in traffic. WILL IMMEDIATELY COOL DOWN WHEN RPMS ARE INCREASED TO 3500 FOR 1-2 MINUTES. nO WATER PUMP NOISE, NO LEAKAGE, COOLANT LEVEL IS oK, ELEC FAN OPERATES...
Hello and welcome, it sounds like you need to replace your fan clutch. Your Jeep has 2 cooling fans 1 runs off the engine the other is electric. Before replacing the fan clutch you need to make sure the electric cooling fan is working just turn on your a/c and it should kick on. If it does then the problem is your fan clutch is it doesn't then your electric fan is most likely bad.
Jun 23, 2011 | 2005 Jeep Grand Cherokee
The cooling fans just work with the a/c on
the cooling fan circuit switches the cooling fan on using a thermo switch ,which is usually mounted in the thermostat housing,it will have 2 x wires ,if u bridge these together and the fan comes on ,then the swiych is faulty, if the fan doesn,t come on u should check the fuses
Mar 07, 2010 | 2000 Buick LeSabre
Cooling fan
Here are the cooling system diagnostic steps...First does the cooling fan kick on (with engine hot)? If not, check the fuse, if good then check the thermoswitch in the radiator (it's about an inch and a half in diameter located on the lower part of the radiator with two wires ) by disconnecting the wires and touching them together (again, with engine hot...at least 190 degrees) if the fan comes on, you have a bad switch. If not connect a 10 gauge jumper wire from the battery to the fan itself (there are three terminals,,, one high, one low and ground). With power direct from the battery (and a ground wire, if necessary) fan should run... if not replace the fan assembly... if it does run then you have a bad cooling fan relay (under the dash, I believe). Hope this helps... ;-)
Apr 19, 2009 | 1995 Volkswagen Passat
Friedrich WY10B33 Air Conditioner Logo
162 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
