Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper goes through but nothing is printed!!
Just moved house and thought I had used same leads and same holes BUT although the lights come on, when I ask it to print it makes all the right noises, pushes the paper through OK but nothing is actually printed! Advice would be most welcome but please keep it simple. thanks
    Problem Solver:
  • 16 Answers
Please check if the print cartridge are installed properly or not. Please try take out the cartridges and then put then in again in the printer. Also check if the cartridge is not dry.
Posted on Jul 08, 2010
Print is very light even after replacing ribbon.
My first thought is that the numbers being "hammered" against the paper are not reaching far enough. Test this theory by putting two layers of paper into the paper feed, (Fold the end of the roll over onto itself) and try printing again. It could be designed for a thicker paper.
Alternatively the new ribbon may also have dried out. Rub the ink ribbon with a paper, or pencil eraser and see if the ink readily comes off, perhaps use a pencil eraser to press it against the paper being fed through the machine.
These are diagnostics to find the error. Further investigation might be to see if there is any particles in the machine preventing it from hammering the numbers against the paper. Something might be in the way of the moving parts, something about the size of a paper hole punch paper, or pencil shaving. Shaking it vigorously upside down might solve this problem.
Good luck ;)
May 10, 2016 | Canon P170-DH Calculator
HP LaserJet 4L quit working It's connected to my PC and it's on. All 4 lights are on; 2 green and 2 orange. When I try to print, the paper goes through but nothing is printed on the paper.
Empty cartridge maybe?
Otherwise it's simple: selt-test page(by printer button) printed ok - it's outer problem. Self-page is blank - it's inner problem. And so on... use Golden Section method
Jan 10, 2014 | HP LaserJet 4L Printer
RX700 not printing anything
After two years of no use the ink is most likely dried up and plugging the print head, try this first before you replace the cartridges, soak the print head of all cart's. in hot water for 10 minutes and wipe dry, then try again, if that doesn't work you will need to try need cart's, buy reman ones they are cheap and if the printer is defective you won't be out so much money. I advise you based on my experiences that buying a used printer is risky, a new one is so cheap it is just not worth the risk of getting a DOA used printer. The last printer I bought came with a rebate for the entire price of the printer, and it is a Canon not a no name.
Jan 20, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
Red light stays on, but nothing moving after clearing paper jam
About the last post, I must also add that the main clue that led me to that conclusion, was the fact that, when I first turned the printer on, THE FAN BEGAN to rotate. Hence, I thought, all the other aspects were right, but somewhere there might be a mechanical "jamming" that stops either the fan or other part to move and obstacles the cylinders or gears from moving, hence sending the printer a signal of jamming. I had looked for the "messages" from the printer, and the diagnosis for our problem (red light in the online error, and green light in Toner Save) was that either there was no ink or no cartridge, no paper, or paper jamming (please post if there was other cause for this diagnosis). I discarded the other grounds, so the unique left was that the printer thought was that there was a paper jamming. This lead to the fix I described in my previous post.
Regards,
David López Salgado
Bogotá, Colombia
May 02, 2009 | Samsung ML 2010 Laser Printer
Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
Mar 19, 2009 | Canon Office Equipment & Supplies
Will not print
 ARE YOU USING BROTHER INK??? I MEAN BROTHER OEM INK.? WHAT YOU CAN TRY IS TAKE A PAPER CLIP AND INSERT IT ABOUT 1/4 OF INCH INTO THE AIR HOLE ON THE CARTRIDGE, SOUNDS LIKE WHEN THE SEAL WAS TAKEN OFF, THE ADHESIVE FROM THE SEAL STAYED ON THE CARTRIDGE BLOCKING THE HOLDE. GOOD LUCK SR BROTHER TECH
Dec 01, 2008 | Brother MFC 7300C InkJet Printer
Messy prints
not a solution but i have the same problem, found that buying bottles of fuser oil and adding it regularly to orange foam rollers found under fuser oil unit helps although 1st page printed will be covered in oil. also i have cut holes in top of fuser oil unit so can keep a high level of oil. i have 5 of these printers all with the same problem.in my search for a solution came across this, rings true to me. http://www.dec.com/sbso/expert/competitive_ricoh_reliability.html
Nov 08, 2007 | Ricoh Aficio CL7000 Laser Printer
R1800 printer problem
I fixed the problem, the PW and Ink Mark sensors needed cleaning. I was able to access and remove both sensors after removing the printer housing, and moving the print head to the far left. There's enough space to unscrew the cover for the sensors, and unplug them with needle nose pliers and a couple fingers, clean them both, dry them, re-install, etc.. all is well now after some re-alignment procedures with the epson factory service program.
Oct 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Nothing prints on the paper for incoming faxes or copying a document.
i suspect you are correct in cleaning the unit.inkjets if not used often enough the ink will clog the print head. usually the easiest solution is to keep cleaning unit it works again. other wise to clean the print head manually requires the unit to be completely dissambled. it takes a long time to fix it this way. or if replacement costs are acceptable you can replace it. i would just give it a dozen or so more cleanings.
Aug 23, 2006 | Samsung SF-335T Plain Paper Inkjet Fax
Canon PIXMA MP210 Photo All-In-One Printer Logo
266 people viewed this question
old marine
old marine
