Question about Strategic Simulations Inc. Panzer General 3-D Assault for Windows
Looking for an update and patch download for Panzer General III
Need download
Does anyone know where I can buy online after-market decals for an Ialeri brand 1/35 German Panzer I model?
It would help if you first find some pictures of the actual tank, then you could try contacting this company: http://www.model-supplies.co.uk/ or other companies that make reproduction decals for models and old toys. The Maidenhead Static Model Club is another possible contact point for you to try. Good luck!
Jan 08, 2015 | Crafts & Hobbies
Tip
Quicken will not print more than seven checks.
You may run into this problem if you use the 2005 or 2006 version of Quicken’s personal finance software (such as Quicken Basic, Deluxe, Premier, Premier Home & Business). If you try to print eight or more checks at once, they won’t print.
According to Quicken Help & Support, Intuit fixed this problem for both the 2005 and 2006 versions of Quicken. You’ll need to download and install the latest patch, which includes the fix for this problem. Quicken offers manual and One Step Update methods to update your version of Quicken with the latest patch. You’ll need an Internet connection to download the patch. If you have a dialup connection, connect to the Internet before you start any of the update methods below. Once you complete the patch installation, Quicken will be able to print eight or more checks.
To read Quicken’s solution for this problem, visit www.quicken.com, click Help & Support, and then select 2006 For Windows (make sure Quicken For Windows and Quicken 2006 appear in the Product fields). Next, type 2997 into the Search field and click Search.
Update Quicken 2005 manually
Visit Quicken Help & Support, select 2005 for Windows, and enter 3810 in the search field. Open the How Do I Manually Update Quicken 2005 For Windows To The Latest Release? link. This page has all of the patches for Quicken 2005. However, you only need to download the patch that has the highest R number. The latest patch carries all of the data from the earlier patches. In this case, you will want to download patch QW05R5PATCH.exe.
Click the file’s link. If you have Windows XP, a File Download – Security Warning may appear. Click the Save button. In the Save As window, choose a location to which you’d like to save the file and then click Save. When the download completes, simply double-click the file to start the patch installation.
(NOTE: This method involves downloading and installing a single patch file. If you don’t have an Internet connection but have a friend who does, you can download the file to his PC and then burn it to a CD [assuming your friend’s PC has a CD-RW]. Use the CD to transfer the file to your computer.)
Update Quicken 2006 manually
Visit Quicken Help & Support, select 2006 for Windows, and then enter 3796 in the search field. Open the How Do I Manually Update Quicken 2006 For Windows To The Latest Release? This page has all of the patches for Quicken 2006. However, you only need to download the patch that has the highest R number. The latest patch is QW06R3PATCH.exe and carries all of the data from the earlier patches.
Update Quicken 2005 Or 2006 With One Step Update
You can also update your version of Quicken using One Step Update. You can start the update by clicking Online Menu and then selecting One Step Update. Next, uncheck any checkboxes that appear and then click Update Now. The tool will download and install the latest update for you.
by: -micromaster
on Mar 19, 2008 | Intuit Quicken Basic 2004 (028287007543)...
For Singer Futura CE 250. New laptop with windows 7? Loaded software & tried 64 bit Vista update patch - it doesn't work. Is the newer patch available for download? Can't use Live Update because...
Update with WIndow 7 support is already available at:
http://www.futura-support.com/downloads/ce150.html
If you applied wrong patches you will have to uninstall Futura, reboot, install from the beginning the basic version and then apply an update 3.0.0.9
Jan 03, 2010 | Singer CE350
I bought the tauchpanzer 3 tank but it came with it smoke switch missiing any ideas if i can get a new switch
contact the manufacturer or the store that you got it from. They should be able to provide a replacement switch.
Dec 29, 2009 | RC 1/16 Tauch Panzer Iii Radio Control Rc...
In death match mode the pc resigns within in minutes of starting
you need to update your game. that is a patch that fixes that programming glitch. You will find it here.
http://download.microsoft.com/download/aoeaok/Update/1.0/W9XNT4/EN-US/age2cpfix.exe
Sep 09, 2009 | Microsoft Age of Empires III: The Asian...
I cant play warlords battlecry 3 on windows vista. What do i do?
I play Warlords Battlecry 3 on Vista all the time, are you using 64 bit? if so then it will not run ever.
Jul 05, 2009 | Enlight Interactive Warlords BattleCry 3...
MacPro, Civ III Complete with Intel Update
Figured it out: http://support.aspyr.com/index.php?x=&mod_id=2&root=239&id=598
Make sure you have the 1.22 Rev A patch and then get the new fix (both links are on the page linked above).
Jan 30, 2009 | Macsoft Civilization 3 for Mac
I have problems using software. I was told there's something called a "patch". what is it?
A Patch is an update to the software, which updates the program. Usually it fixes bugs or adds new features. Some programs have an option to "Check for updates" on the About option.
Others require you to go to the manufacturer site, and download the patch from an Updates (or Downloads) page. They usually give you instructions on how to install it on the same page.
The general idea is to save the patch to your computer, then double-click on it. That usually starts the install.
If you need more specific instructions, post a follow up here with the software name and we can give you more help.
Here's a tip - when you post questions here, try to be a bit more specific about your issue - what software, what problems. You'll get a faster answer that way.
Good Luck
Jul 25, 2008 | Computers & Internet
Processor Overheat
Biostar M5SIB is Socket7 motherboard and can support maximum upto AMD K6-III 500MHz (83MHz*6) - with patched BIOS. You can download BIOS Patcher at: http://rom.by/articles/BP/index_english.htm or use another already patched bios: http://home.hccnet.nl/j.steunebrink/M5sib_j2.zip Intel Pentium III has Slot1 or Socket370 CPU-connector and you can`t use it at your Socket7 (M5SIB) motherboard.
Apr 07, 2007 | Sis (M5SIB) Motherboard
Strategic Simulations Inc. Panzer General 3-D Assault for Windows Logo
52 people viewed this question
Top Strategic Simulations Inc. Video Game Consoles & Games Experts
James Wishart
Are you a Strategic Simulations Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
