Question about Nintendo DS Lite Console
DS Lite shuts off when it is closed or the back is hit hard enough
I first noticed this problem just yesterday. I was playing my DS Lite, and I closed it to go and do something, and when I opened it back up, it was turned off. I didn't think this was a big deal because I don't really shut it that often, but today when I was playing, I left it open and put it down, and it shut off. I tested it out a couple of times. I turned it on, and tapped the back of the DS and found that when you tap the back more towards the power button, it shuts off. Does anyone know what's wrong or have any solutions? Thanks!
    Champion:
  • 268 Answers
Your DS is having a circuitry problem and you may have to get it sent off for repair before the problem gets worse, the cause of this could of been 1. dropped it accidentally or 2. its having a hissy fit.
Posted on Apr 20, 2008
Hi, I have a DS Lite 2 years old and I noticed that in several games it´s turning off suddently while the game is running. Restarting, the game starts from the beggining.Sometimes the problem appears...
If you have dropped or bumped the ds lite hard against something then it's possible the black coil near the power switch is loose. This can cause it randomly shut off. The coils is the round topped black thing with 100 printed on it. There are several on the motherboard but you're looking for the one closest to the power switch. Just heat up the solder on both sides of the coil and it should reseat it.
Jan 05, 2010 | Nintendo DS Lite Console
Nintendo ds lite that shuts off unexpectedly
Hi again,
Ive been doing a bit of research and it seems that if the DS lite has had a knock the black coil near the power switch could have been knocked loose which would make the DS lite switch off randomly. If you want to see if thats the problem take the DS lite apart (for a dismantle guide click here) and check to see if its loose... its the black round thing with 100 written on it near the power switch. If its loose then heat up the solder round it and that should reset it.
If thats not it check the L2 transistor is firmly in place, again if its loose heat the solder and reset it.
Another thing you can check is the power switch make sure its solid and doesnt wobble internally i.e. the black moveable part only moves the way its supposed to, as well as checking the solder is solid.
Hope this helps, if it doesn't sort out your issue then get back to me and I will continue to help you.
Regards,
SOD69
Jan 04, 2010 | Nintendo DS Lite Console
Microphone not working i bought it just 3 days ago but when i played a game it said blow i blew nothing.
Very first thing, please ensure that you were close enough to the microphone for it to pick up on you blowing into it, it at a distance of 5 inches it still doesn't pick up you blowing into it, follow one of the following solutions.
The DS Lite comes with a one year limited time warranty, as long as they can't blame you for the microphone not working you can send it into Nintendo and get a replacement for free. So it is best that you don't attempt to fix it yourself.
Or a better solution is if you bought it from Wal-mart, and possibly some others stores, they will accept the DS Lite back for a swapped product and they will go through the process of getting the DS fixed or replaced. Make sure you bring your receipt so you can prove you bought it 3 days ago!
Hope this helps.
Jul 15, 2009 | Nintendo DS Lite Console
My ds is automatically shutting down..
put the charger in and then turn it on
Jun 19, 2009 | Nintendo DS Lite Console
Gameboy DS lite turns off when B button is pressed any harder than a tap. Gameboy also turns off randomly.
Your DS Lite is grounding out. Take it apart and look at the back of the Bottom LCD..
Has it had any recent liquid spills AT ALL?
May 27, 2009 | Nintendo DS Lite Console
DS Light shutting off randomly
I know this may sound stupid and obvious, but are you hitting the power switch while playing? I used to have the same problem when playing "intense" games like racing when I would get totally absorbed and then all of a sudden my DS would shut off and I'd be like WTF?! I took it apart and switched batteries and found nothing wrong with it. One day my sister was watching me and asked "Why did you shut it off?" and then I knew. The power switch is very sensitive if you hit it even just a little it could be enough to shut the power off. I suggest just monitering what happens when the power goes off. Is it a specific game that shuts it off? Enviornmental effects? It should tip you off to the problem. If all else fails you could contact Nintendo and just see what they have to say. =)
Mar 29, 2009 | Nintendo DS Lite Console
DS Lite Shuts down when closed instead of pausing game
Make sure before closing the DS that your Battery is Charged. If you have to step away for a considerable amount of time, plug the DS in to the AC adapter then close the DS.
You may also want to check out the battery to make sure that no moisture has gotten in to the case. Just a little moisture can short out the DS and Shut it down. You also can check online to purchase a new battery for the ds. They gave one available at Buy.com for 6.99.
I hope this helps. Take Care. =)
Dec 08, 2008 | Nintendo DS Lite Console
Lower screen flickering
ITS NOT HARD 2 TAKE IT 2 A REPAIR SHOP
Jul 27, 2008 | Nintendo DS Lite Console
DS Lite shuts off when I press the B button, and at random.
that happens when i click my laptop buttons too hard... i think u should try to wet it a bit and dont press TOO hard
Sep 30, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
64 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
