Blower motor run for ten to fifteen min. then stops makes a humming noise on motor.cools down and then will run for the same amount of time.
  • 43,501 Answers
The motor is going bad...you can try to oil it, that may help..
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
After running for awhile when i stop it makes a humming noise and when i start after 25 miles an hr the noisestops
Sounds like your electric cooling fans are working properly...any change in coolant temp in these situations?
Jun 17, 2015 | 2000 Mercury Grand Marquis
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
I have a weather king furnace and the furnace runs all the time.
first check your high limit switch find the white wire coming from your blower moter and unplug it hold down your door switch to see if your furnace will shut off if not replace it and your blower will run for ten to 20 min or until your heater has cooled down.
Jan 04, 2013 | Heating & Cooling
Drum turns, getting humming noise after running for short time.
You will need to check the drum rollers. Sounds like one or more may be failing. Here is a link to the part.
Here is a video to show you how to make the repair.
Oct 16, 2012 | Frigidaire Dryers
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Blower motor runs but dies out..
When it does this carefully feel the end of the blower motor. If it is too hot to touch,Replace the blower motor.
Your 5 minute off sequence allows the motor to cool enough for a restart.
Apr 08, 2009 | Amana PTH153B50AJ Heat Pump Air...
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Toshiba 46HM95 Buzzing
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Apr 02, 2008 | Toshiba 46HM95 46" HDTV
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
