Question about Dell Audio Players & Recorders
My Dell A225 Speakers do not play audio- just the computer sounds.
  • 2,359 Answers
Test this setup with your walkman/ipod.
The most likely problem is in your computer's mixer selection.
Put a CD into your computer drive and play this CD.
If the CD audio output is low then dial up the mixer CD output.
If you do not has audio via CD at all then the CD drive to sound card audio cable is disconnected.
Posted on Jul 08, 2010
Not working Dell A225 2 Speakers
Try the speakers on a different computer.
Try a borrowed set of speakers on your computer.
Go to any "Thrift Store" and pay $5 to $10 to replace the speakers.
Feb 02, 2014 | Dell A225 2 Speakers
How to open speaker of model DellA225
how to repair SPEEKER dell A225
I have a Dimension c521 desktop Dell computer. Where do I plug in speakers in the back?
You need to look for the Audio-OUT 3.5mm jack on the rear of your computer chassis. It is usually colour coded green. If need be look at the rear out-puts, some-times there are small pictures indicating either Audio out.
Take care!
damnor01
Jul 17, 2011 | Dell A225 2 Speakers
Dell a225 2 speakers light on fully plugged in..
Try going to "control panel", then "sounds and audio devices" (in XP, should be the same in newer OS's). Click on the "advanced" button under Device Volume. That brings you to "volume control". Make sure the levels are up and the device is not muted.
Jun 26, 2010 | Dell A225 2 Speakers
My speakers wont work
Go to Control Panel, then Sounds and Audio Devices. Make sure the volume slider you see there, is turned up. If so, click on the Advanced tab, then check to make sure that those levels are turned up, and that nothing is Muted.
Jul 08, 2010 | Dell A225 2 Speakers
How can i open the speakers? I want to change the cable of my dell a225 speakers.
Dell A225 speakers.
What I used to disassemble / assemble mine:
Sewing needle;
Soldering iron;
Philips screwdriver;
Hot glue gun;
Have patience.
Use a sewing needle to pull the front grill of the speaker, carefully by the edges. Do not pull too hard, go pulling around the screen to prevent warping.
Loosen the two small screws at the base of the box.
Loosen the six screws you see, the top four has a glue to prevent vibrations.
The card is only snapped, just pull it.
Use the soldering iron to soften the hot glue that holds cables and presto, its sound box is open.
When mounting, use the hot glue to hold it again, to avoid vibration at the time of use.
Sorry for the lack of pics.
Hugs from Brazil and good luck!
Jun 19, 2010 | Dell A225 2 Speakers
I want to know how to open my dell model A225 computer speaker
Dell A225 speakers.
Sewing needle;
Soldering iron;
Hot glue gun;
Have patience.
Sorry for the lack of pics!
Jun 04, 2010 | Dell A225 2 Speakers
Speaker will not work. Cannot adjust the volume.
Make sure you can see the small LED light on the speakers. If I remember correctly, those speakers are USB powered, and need to be plugged into the USB port for power, and the green audio output port for sound signal. If they are plugged in, and you cannot turn them on, you have broken speakers. If you CAN turn them on, then ensure that the audio cable is plugged into the green audio output jack (sometimes it has a headphone icon by it) and make sure your computer has not muted the audio.
May 17, 2010 | Dell A225 2 Speakers
Speakers
It's not with the speakers. Try checking the audio settings of your computer.
Apr 28, 2010 | Dell A225 2 Speakers
102 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
