Question about Canon SmartBase MP360 All-In-One InkJet Printer
Machine shows "cover open"
Even i closed the cover, the machine shows "cover open" and don't allow me to do anything, what should i do?
No error code ## 343, but will not print now. How can I change from English to Finish languages in printer?
Posted on Aug 18, 2010
Kyocera taskalfa 1800 is showing add toner on its screen even after another toner has been fixed
While the machine is on, you need to put the old toner back into the machine, close the front cover. Open the front cover and replace it with the new toner. Make sure new toner is shake well.
Mar 01, 2017 | Kyocera Office Equipment & Supplies
The red light blinks under the coffee bean?
The red light on the front of this machine is simply to let you know that there is some issue with the machine: it could be that the grounds receptacle is full, the machine is out of water, or it doesn't have beans. Please check all three areas. It may be that the receptacle, even if empty, may not be pushed all of the way in. Even if the water reservoir is filled, it may not be properly seated on the valve. If the beans appear to fill the bin, it may be that they are not reaching the grinder for some reason and need to be pushed under the tray which shields the grinder. Finally, once you've check these issues, you will want to open the front door of the machine as if to get to the inside where the grinder is housed and then close the cover door. This will then cause the machine to reset. Note, you don't need to do anything other than just open the front cover from the left side as it swings on a hinge on the right and then close the cover again. You can also turn the machine off and on again to cause the machine to reset. This will take care of your issue of the blinking light, assuming you've corrected one of the three things above that originally caused the issue.
Oct 18, 2011 | Saeco Vienna SuperAutomatica Coffee...
Fax display says, close back cover even with back cover closed.
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Showing a L5 code and won't do anything even if I take everything out.
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Display screen says: door/covers open close covers of relay unit??
I believe the "relay Unit" on that machine is the section that transports copies to either the finisher (if installed) or the exit tray on the LEFT side of that machine. Sometimes neither of these units are present, but the relay unit may still be installed.
There are 2 flip up covers on that section (left and right), and you will probably see that one of them (usually the left one) has come unclipped, or perhaps the plastic clip that holds it closed is broken. If you flip up this unit. You will see a black button at the back end that is engaged when ther unit is closed. If you simply pree this button with your finger, hopefully the message will go away - this may at least help you troubleshoot what is causing the "cover open" message). Even if the clip is broken, it is often just a matter of seating the unit correctly so that the switch is engaged when the unit is closed. There is also the same switch on the right cover that could be causing the problem, but this cover doesn't sem to get damged as often.
I hope this helps. Please let me know.
May 21, 2009 | Ricoh Office Equipment & Supplies
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Paper misfeed indicator light continues to blink even after paper
some machines will want all covers to be opened, then closed, for good reset. if you are having jams in the adf, then open all adf covers, and lift the adf upward, if it allows. also, try turning unit off, then back on. some jams only clear that way.
Apr 02, 2009 | Sharp AL-1641CS Laser Digital Copier
Cover open message
Just check may bi cover is not locked properly .and also check there will bi a sensor having some bad sector .just clean it properly.or replace it MIA AKHLAQ
Dec 17, 2008 | Panasonic KX-FLB751 Plain Paper Laser Fax
How do I reset the Change Drum Soon on the display?
All you should have to do is: -replace the old drum with the new replacement. -with the front door open press the Clear/Back button -press the number 1 button and when ?accepted? appears on the LCD close the front cover. That should do it. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
107 people viewed this question
old marine
old marine
