Question about Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore Elite Oasis HE top loading washing machine. Once it fills with water and starts to spin it makes a clicking noise. Not sure if something is loose with ref to the basket but it just started making this noise. Any suggestions how I can fix that?
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
I have a Kenmore Elite Oasis HE top load. The machine sounds like a thunder when it spins, and also a pond of water leaks on the floor.
Check your hoses for leaks or possibly the drain it's draining in is clogged or half clogged or too clogged to accept large amounts of water all at the same time. Not to sure bout the thunder part. Lol
Jun 13, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
I have the kenmore elite oasis it turns on and just makes a little noise and counts down the minutes but doesnt fill up drain or spin.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 18, 2011 | Kenmore 24032\24036 Top Load Washer
Machine stopped in the spin cycle, now only makes noise.
Be sure BOTH fill hoses are hooked up and TURNED ON. What happens is (commonly) hot and cold hoses are installed reversed, and no one really notices.....Then Dad gets a big hot water bill and turns off the HOT water (actually hooked up to the cold input on the machine), so when the machine gets to the rinse cycle, no water comes in, and it waits patiently (forever) for water which never comes. The buzzing is the water valve. This is the most common problem.
Dec 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Makes a raddling noise when draining
There is stuff caught in the drain pump...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I hear gravel noise when the machine changes cylces
The machine does a quick test to determine if the spline is engaged before spin commences. The way it works is the tub fills with water and floats for wash. When the pump removes the water for spin the spline don't always line up. So artificial intel will give it a slight test to see if the basket is locked. I have a bravos manual that shows how it works I know yours is an Oasis but I believe these are all basically the same. See page 23
Apr 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Agitator grinds and won't spin
You have a broken motor coupler, you can see how it is replaced on samurai appliance guru
Jan 17, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Oasis HE 27082 Top Load Washer Logo
56 people viewed this question
fordexpert
Mike Squire
Robert Rankin
