Question about Lite On LTC-48161H CD-RW/DVD-ROM Burner
HOW TO REPAIR DOOR ON BURNER - Lite On LTC-48161H CD-RW/DVD-ROM Burner
  • 212 Answers
What problem it have exactly?if it cant bring out correctly,its depend on the lever & inside motor of it.sometimes must change a plastic part that move the lever in & out by motor.
Posted on Aug 11, 2010
No leee cd de arranque
Posted on Jun 15, 2013
How to fix la germania burner?
Guess you mean a kitchen appliance not a cd/dvd burner! The only way to help you giving some advice about how to fix ut is if you tell us the problem you need to fix.
Describe your burner: is it a gas burner or an electric burner?
Had you repaired something similar before?
In any case, watch some youtube tutoriasl to repair a burner
Cooktop Range burner not heating burner light is on GE Hotpoint RCA...
GE Hotpoint RCA Gas Stove Repair Burner is not working JGSP44BEY3BB
Prego Project Fix GE Stove Burner
Stove Oven Range Burner Repair Diagnostic GE Hotpoint Kenmore Sears RCA...
Aug 19, 2015 | Computers & Internet
On my Electrolux wave touch range, the burner buttons remain lighted, won't go onto sleep mode and when touched will not cause a burner to begin heating. It's as thought they are all stuck in the ligh
Hello friend, thank you for your post!
I understand that your Electrolux range burner buttons are remaining on. I have identified a few possibilities as faulty burner buttons, bad switches, or a disruption inside the control panel. Let's perform a reset on your range which can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue I would suggest consulting with a professional for proper repair. Hopefully this helps. -Matt
Oct 11, 2014 | Electrolux EW30MO55HS | 30" Built-In Drop...
CD rom will not read any CD. I insert CD and press read button. The door closes then immediately ejects. When I shut down the computer, the CD door will close. When I restart the computer, I cannot...
Operating System that support your device: IBM OS/2 · Linux · Microsoft DOS · Microsoft Windows 2000 · Microsoft Windows 3.x · Microsoft Windows 98 · Microsoft Windows 98 Second Edition.
I think your device is bad and is no worth to repair it.Or try to update the firmware at LINK
Dec 10, 2010 | CyberDrive CW078D CD-RW Burner
My heat will not cycle on the blower motor continues to run even if I turn my thermostat off. I have pulled the disconnect out twice and I still can't get the blower to turn off .Gas burner won't ignite....
One thing to try is to remove door from blower compartment and see if that shut the blower off, There should be a switch on the edge of the furnace frame that is turned off when the door is removed. Also look in the burner compartment and see if you can locate a small silver fuseible link close to burners. If your furnace has this then use ohm meter to check across it and if it reads open then temporarly jumper it . Put blower door back on and see if this stops the fan running. Not all furnaces use this link but it one easy thing to check. Hope this helps. Thanks
Dec 07, 2010 | Heating & Cooling
Door will not open
Straighten a paper clip, locate the little hole in the drive door, insert the paper clip and give a little push on it. This is a release button in the event you can't power up a computer. If it still does not open you will probably need to replace it, getting it repaired will be just as much if not more probably.
Sep 21, 2010 | Sony VRD-VC10 DVD±RW Dual Layer...
My dvd writer has stoppe workin canu tell me can i repair y self or it can be repairable ror i have to buy a new one
Buy a new one - they run from 24$ up
you can sometimes repair the physical in/out door motion but it's far better just to buy new than field replace the optical lazer
sometime you can flash a DVD with new code and they'll start to work
Aug 24, 2010 | Samsung (SH-S162L/BEBN) DVD RW Burner
Drive door stuck and wont open
You can always try getting a jumbo paperclip, unbending it once, and inserting it into the small circular hole on the front of your drive. If your drive doesn't have the hole, then you'll have to probably take it to a repair shop.
Good Luck!
Jan 23, 2010 | Sony (DRU720A) DVD±RW Dual Layer...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Burners go out before the fan starts
that makes no sense? the door on does exactly the same thing as you holding the switch closed and neither has anything to do with the problem you are describing. if door were off nothing would happen. if door was on ,nothing would happen unless the switch was closed. it may be coincidence, but sounds like the unit is not proofing the flame. look for a little needle like sensor that protrudes into the flame path in front of a burner. when the burners light it senses flame and tells gas valve burners lit and its ok to stay on. then heat builds and the fan is briught on. once in a blue moon the overtemp sensor trips open prematurely as soon as the burners start to heat up. it is a little wire in , wire out sensor above the burners that protreudes into the bulkhead above the burners. if it is cold and open its bad. if you jump it and burners light and stay lit and fan comes on its bad. fairly cheap and easy to replace. you may have an old fan limit switch the rotates like a spring to bring the fan on as it heats up, then turns off burner if its gets to hot or is set to low. it also turns fan of as burners cool down.
Dec 05, 2008 | Heating & Cooling
ASUS 52CD-writer's door is stuck....
Is the door stuck shut? If so there should be on the front a little hole about the size of a pin. Unfold a paper clip insert it into the hole and push firmly this will open the door. If not you can remove it from the computer and unscrew the sides allowing you access to the insides.
Thanks J
Nov 25, 2007 | ASUS (CRW5232A/QTWHT/G) CD-RW Burner
Lite On LTC-48161H CD-RW/DVD-ROM Burner Logo
87 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Computer Links
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
