Question about Garmin nuvi 260W GPS Receiver
Picture of computer and modem in screen when I plug in charger and cannot use gps.
    President:
  • 1,111 Answers
You can try and reset it by pressing and holding the lower right corner of the screen, the slide the power switch to the on position till it starts..once it starts, let go of the power button and when you see the screen "do you really want to erase your data, let go of the screen and select yes and follow the instructions.
if that fails, your charger is probably faulty or maybe you just replaced it with a generic one...find another charger to try.
if that fails (i recommend this either way) download the web updater (HERE) and update the nuvi if you havent already.
normally the charger has gone bad, or a generic charger is the cause
if you need more help, just post back
bill
Posted on Jul 09, 2010
My garmin 780 doesn't operate with the car charger plugged in. goes to a scenery photo that has a small picture of it plugged in to a computer at the bottom of the screen, and does not load. is that...
hi danielktx, its doing that because it thinks the charger is the USB cable and connected to the computer...either you have the wrong charger (is it factory or after market) or the charger it self is faulty.
Bill
Standing Member of G.O.T.
Please Support Our Troops
Sep 18, 2011 | Garmin nuvi 780 GPS
When I plug my nuvi 260w into car charger, the screen goes blank with a picture of unit hooked to computer. I cant use the GPS unless I unplug from charger
Sometimes this happens because the plug of the charger is not fully pushed into the back of the satnav. It feels like it is but it's not. Pushing it in further may solve your problem.
Jun 11, 2011 | GPS
When I plug my Nuvi 265w unit into my car charger a screen appears with a computer on it and a loading screen. The screen then loads and allows me to use the GPS. Randomly this will re-occur when I am...
Sometimes this happens because the mini USB plug of the charger is not fully pushed into the back of the satnav. It feels like it is but it's not. Pushing it in further may solve the problem.
Jun 06, 2011 | Garmin nuvi 265 Car GPS Receiver
I have a garmin nuvi 200. I'm having problems trying to charge the device. I have tried charging it in my car as well as the computer. Once I try charging it a black screen appears that says garmin as...
This is meant to happen when it's connected to your computer but not to your car charger. Sometimes it happens, when connected to a car charger, because the mini USB plug on the charger lead doesn't go in far enough into the satnav. It feels like it's fully in but it's not. If you push it in further it should solve the problem.
It takes 8 hours approx to charge a satnav connected to your computer but only 4 hours approx with the car charger or mains charger.
Apr 22, 2011 | Garmin nuvi 200W GPS Receiver
When the gps is on a picture of a computer display's on screen and then gps turns off
The USB plug at the back where the charger goes is shorted.
Apr 01, 2011 | Garmin GPS
After connecting to car charger or computer. screen has picture of computer and cable, but main screen can not be accessed. Device operates fine when not plugged in.
When it's connected to a computer it's supposed to have this picture. It's not meant to be accessed except through the computer since files are updated in this setup which could not happen if the main screen was being accessed.
When connected to a car charger this should not happen. Sometimes it happens because there is wear on the mini USB socket on the satnav which causes the plug to stop, when you're plugging it in, before it's in fully. Push it in further and the problem should be solved.
Jan 19, 2011 | Garmin nuvi 205W GPS Receiver
When I plug the gps into the charger a computer picture shows up and I can't get it on any other screen. What's the matter?
Did you recently purchase that charger?
This usually happens when the charger is not compatible with the unit. or you could be using a non-Garmin charger. There are some "store-brand" chargers that work well, and some do not. Store brand Charger are made to be Universal. To fit multiple devices and maximize profits. You want a Garmin Specific Charger, and here is the logic why...
The reason behind it:
1. The Garmin USB Cable that you connect to your computer has a special 4-pin configuration telling the GPS that is is connected to a computer. This is the configuration most "generic" chargers use to maximize device compatibility.
2. The Garmin Car Charger has a different pin configuration with 2 less pins, giving it only positive ( + ) and Negative ( - ) to charge the GPS.
When the GPS receives the 4 pin, which is also found in a "Motorola" Cell phone charger, it will automatically sense that it is connected to a computer.
Long winded, but I wanted to explain why. Simple fix, Just go get a new charger and make sure it's Garmin compatible.
Jan 04, 2011 | Garmin nuvi 255W GPS Receiver
I have just purchased a sendai universal home charger, when I plug it is my Garmin 200, and the other end into the electrical socket I get a picture on the screen, looks like a computer with a plug running...
The nuvi thinks you've connected it to the USB port of your home computer. It's charging, so pay no attention to the screen.
If you HAD connected it to the USB port, you would also see the nuvi as a storage device attached to your computer. That's how you can download pictures that you can display on your nuvi. It's also the mechanism used when you update your maps and/or software.
Apr 16, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
276 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
