Question about Averatec 3200 Notebook
My jack is bad
My jack inside the laptop ,not the adaptor its fine.jack is loose and i have to hold it to get to work is it a easy eternal fix.thx
  • macnor Apr 24, 2008
    I have bought the replacement part. I just need to know how to open the computer case.
  • savingdollar May 06, 2008
    I have the same problem...my dc jack is unstable on my averatec 3200. i thought i would need a new laptop but this may help save me several hundred dollars...need to find a solder though.
Http://www.flickr.com/photos/dnhoshor/sets/72157602004333279/show/
This is a photo guide for your exact problem Not exactly easy but if you or a friend is skilled at disassembly/soldering... the part is about $10.00 on eBay just look for averatec 3200 dc jack. Needless to say if you do not feel comfortable doing this sort of thing take it to a local repair shop
Posted on Apr 23, 2008
How do i replace to charging coil on my laptop
You Probably need to replace the DC Power Jack which is where the laptop plugs into the computer. If it is loose then it is bad. Take an ink pen and push the tip inside the jack and see ifthe little pin wiggles, if so the jack is bad. You'll have to take the laptopapart to fix it. Most times it is soldered onto the motherboard, so youwill have to desolder the old and solder a new one.
Make sure your power cord is good. Some powercords have a light on the adapter portion that lights up when plugged in.
May 08, 2012 | Gateway Computers & Internet
Sansa clip headphone jack -- headphones work fine on other players or phone, but clip plays only one ear. If i jiggle the headphones thingie inside of jack i get sound in both ears sometimes. 1) Any...
the jack inside the unit either is bad or the solder connections are bad...you can re-solder the jack(if you know how to solder) and see if this fixes it...or else you'll have to replace the jack(which may be avail. through Radio Shack)
Jan 14, 2011 | SanDisk Sansa Clip MP3 Player
Will not work with ac power adaptor but does with
Did you wiggle it a bit when plugged in? You can't tell from looking on the outside if the plug is fine because it goes bad inside where it is soldered. This is a very common problem, and have fixed many laptops with the same problem. All of them had a bad solder connection inside. Did you dtermine the plug was fine by plugging another ac adapter to your laptop or you just checked it visually? Hit me up I will solve this one for you.
Aug 12, 2009 | Compaq Presario 700 470024-192 Notebook
Why won't my lap top stay on ac adaptor?
you posibly have a SHORT in the wire for AC power- try another power adaptor./ the other cause could be a bad power jack on the laptop- not an easy fix.
Aug 03, 2009 | Toshiba Satellite A215-S7422 Notebook
My laptop isn't charging. I think the chargin port is lose. Is this a common problem? ANy fixes?
There are 2 common problems that end up with this.
1. Battery goes bad
2. Were ac plugs into unit becomes loose/damaged
There is no easy way to fix the connector is must be replaced by a laptop specialist and can get expensive. There are 4-6 connections holding the part to the motherboard and your looking at about 1/2 hour to 1 to just take the unit apart. Part general costs 12-30 bucks based on make and model. We have seen many of these come into our shop.
Thanks, Frank Z.
3868607368
http://www.attechcomputers.co.cc
Jun 25, 2009 | HP Pavilion G60-120US NoteBook
No Power
there is a chance of battery failure
Feb 14, 2009 | Dell Inspiron 600M Notebook
Ac adapter
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
The laptop would have to be taken apart and the DC connector resoldered.
This would cost $75 - $100. Enter your zip code in the box on the right hand side of the FixYa page to find someone close to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 17, 2008 | Dell Inspiron 1501 Notebook
Power Supply problems
hello :
Sir u are facing a probleme with your ac adaptor jack in your laptop maybe yo need to change it .
changing of a ac adaptor jack its not an easy task you will need a soldring kit & a new propre jack for u laptop
dont forget rating this post if this is not helping u tell me so i can help u further .
Aug 20, 2008 | Acer Aspire 3000 Notebook
Acer apire 3000 a/c adaptor
Why did you have to buy a new adaptor? Did it suddenly stop working or was the problem intermittent?
It's my guess the adaptors are fine - very unlikely all three are bad - It's the connector in the laptop that's the problem - it's loose or was pushed too far in at some point so it can't make a tight connection. A good tech should be able to solder it on the inside. Hopefully, you can return at least one of the adaptors.
Good luck.
May 27, 2008 | Acer SPK 2 PCS 120W RMS 40HZ- 20KHZ BLACK...
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Averatec 3200 Notebook Logo
60 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
