Question about Miele 24 in. Incognito G843SCVi Built-In Dishwasher
Drain/intake light is on
I have cleared drain and checked hoses,
machine drains, fills but motor won'y start. is there a way to unfreeze motor and if not what is replacement cost of the motor
thanks
A re-post from John. I am reposting because I read this post this afternoon and it fixed my Miele incognito Dishwasher.
Hi All,
Thx for all the tips. Combining your thoughts provided a solution for me.
I had the same problem (with a ***** of thanksgiving dishes to do). Turn on,
tries to drain, then that RED blinking "INTAKE/DRAIN" light, like you described.
Spent hours, checking/clearing the (grey) drain hose (The other white hose is the water input to the dishwasher). Also took out metal filter, impeller cover, poked a coat hanger in both ways to/from the drain hose connection. All seemed clear. But still the same.
But when I unhooked the grey drain hose from the air gap unit (that part going to the 4th hole in the sink surface), the dishwasher worked fine. So the air gap unit seemed plugged. The black hose from the garbage disposal to the air gap unit is free flowing (blew through it - yuch!). But the drain connection through the air gap unit was NOT as free flowing.
Replaced it with a new air gap unit ($5.00 at Home depot).
All works fine now. I feel I got lucky.
Well this worked for me. Sorry for all of you who spent big bucks with no solution on those service guys that tried but did not help. I hope this helps some of you.
John
Posted on Jul 31, 2010
Washing machine will not drain
Since you've already checked the pump, hoses and motor, here are some additional issues to look at:
1. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
2. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
3. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
The washer broke filled with water and won't drain
see this causes and fix it. God bless you
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Sep 28, 2012 | Kenmore Washing Machines
Washing machine will not drain water
Here are some basic troubleshooting steps you can follow to help you determine why your washing machine won't drain:
1. Check the drain hose in the back of the machine and make sure it isn't kinked or flattened.
2. If it spins but won't drain, there could be a piece of fabric stuck between the inner and outer tub, or even the drain hose or pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. It could also be a faulty timer.
3. Are clothes soaked at the end of the wash, even though it appears to go through the spin and drain cycles? Worn or loose belts could be the culprit.
4. When the spin cycle starts, do you hear a humming noise? It could be a faulty or jammed impeller pump.
For more suggestions on troubleshooting and fixing this issue, check out Washing machine not draining. I hope this helps!
Sep 11, 2012 | Whirlpool Washing Machines
Dishwasher intake/drain light is on, removed and cleaned intake valve, no obstructions. Tripped the breaker to the power supply to no avail....any suggestions?
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Aug 27, 2011 | Miele Touchtronic G894 SC Built-In...
Hi, We have a G638 plus and have it connected to the cold water tap. When we press start, it fills the machine with water and once the machine has been filled, the program doesn't start and after 2-3...
Hi
Daniel
Aug 16, 2011 | Miele 24 in. G638 Plus Free-standing...
Machine stopped mid cycle, won't spin or did not drain, no error code displayed, tried unplugged and restart. no luck
next time send the model number,open the door,look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,it has to drain first before it will spin,check the pump,get a shop vac and vac out all the water,remove the bottom panel and look at the pump,if the middle of the pump can be removed turn it counter clockwise slowly until the water starts to leak out and vac it up until all the water is out,then remove the middle part of the pump and clean it out,if the middle doesn't come out remove the hoses and check the pump to see if anything is in it and check the hoses,after you remove any debries you find fill it with some water and put it into a drain to see if the water drains,if it doesn't you can check the pump again to make sure you cleaned everything out,stick your finger in and fell around the impellar to make sure it's clear,if it's clear replace the pump.usually an error code will come up but if it fills and agitiates but won't drain i would start at the pump.hope this helps.
Aug 15, 2011 | Maytag EPICz 3.7 Cu. Ft.
Intake/Drain light is flashing and dishwasher won't do anyhting. I gve cleaned the filetr and still nothing
Hi
Daniel
Jun 08, 2011 | Miele 24 in. G638 Plus Free-standing...
Miele blinking intake drain light
If you checked the intake water filter and drain filter and still have this problem -- Try this...
1 - You need to take the diswasher out.
2 - Turn it on its side so you can access the bottom panel.
3 - Unscrew the bottom panel
4 - Take off the electric circulation motor (big electric motor with a bunch of hoses going into it (it is the biggest motor -- not the small motor at the front of the machine (this thing actually screws in place from the back of the machine). To take the motor off - just unscrew the bolt from the back of the machine and wiggle the thing out from the seal.
5 - Unscrew the 4 screws (need a one of those special star screw drivers) that hold the motor to the pump mechanism
6 - Turn the wheel to unseize the motor -(it takes very little pressure to do this) and reinstall it -- it will very likely work again (if it does not - you need to replace this motor)
There is apprently an easier way to do this from inside the machine - but meile technicians have a special tool to go in and turn the motor blade to unseize this. It takes very little pressure and I think it would be a crime to pay someone else to do this -- it is so simple....
So, in summary, first check to make sure there are no blockages in the filters - then try this...
good luck!
Aug 08, 2008 | Miele Incognito G818SCVi Built-in...
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Miele 24 in. Incognito G843SCVi Built-In Dishwasher Logo
209 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
