Question about Durabrand 5.1 Surround Sound Computer Speakers
Sound but no picture
I am getting the sound to work but not sure how the plugs go to get the picture as well as the sound
  • 59 Answers
This is an amplifier, it has nothing to do with picture
Posted on Nov 14, 2008
Why does my tv have sound but no picture?
you should be getting both sound and picture..check the video cables in the back and make sure they are plugged in correctly...if this doesnt help, try messing with the settings on the remote...and after that it may be a component problem(picture tube blown, etc.
Sep 08, 2014 | Televison & Video
I HAVE SOUND BUT NO PICTURE
Make sure whatever your playing videos from is properly plugged in. iPod touch or iPhone (via HDMI): the iPhones and iPod touches don't show picture, just sound. TV (via Aerial): make sure is plugged in properly. If your TV remote has a Display button on it, press it again so it comes on. Hope this helps. Get back in touch. Steven :D
Jan 01, 2013 | Televison & Video
Luxor tv no picture or sound
Connect the TV to another power outlet that you are sure, works. Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
ok make sure all the cables are plugged in properly and into the correct slot, Check all the channels and make sure that it is not on AV If this doesn't work try new cables or scart leads, if you use a scart lead plug it into a differnt location E.G Some T.V's Have more than one scart lead socket
Feb 06, 2010 | Televison & Video
On the DVD player the screen is blue and the sound works, but cannot get a picture. The remote will stop & start the sound, but still no picture. This unit is in a 2006 motorhome. On VHS side works...
suspect scart lead, check to see that it is firmly plugged in. Also, many dvd players have a bluescreen/screensaver function, check to make sure this ihasn't been enabled in the system set up menu.
Nov 27, 2009 | RCA RTD300 System
Picture received no audio
Check if ur PC sound card works Fine. If it does Then Open Sound Settings In Syatem taskbat and set LINE IN as recording Plug.Increase The recording Volume of LINE IN.Make sure u plug ur Microphine cable of the webcam into LINE IN slot of ur sound card.Then Check...........
May 26, 2009 | Creative Labs Live! Cam Video IM Pro...
Sound recording problem
Make sure the right sound drivers are installed, make sure your using a working microphone.
Also make sure your using the right program and that the microphone itself is plugged into the jack that is labeled with the picture of the microphone.
If you have done all of this and still can't get the mic to work then its a motherboard problem.
May 10, 2009 | HP Compaq Presario C700T
Disconnected RCA plugs from 52'' RCA and now no sound even...
ont back of the set there are a set of jacks you can hook ext speakers to make sure that switch is turned to int speakers
Nov 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
I have SOUND but no PICTURE
Check the AV plugs those are the red white and yellow plugs make sure that the yellow is plugged into the yellow circle on your tv and red to red and white to white, unless your on hdtv. if there plugged in make sure it is on the right channel probably 3 or 4 if those dont work change it to video mode or input mode.
Dec 25, 2007 | Microsoft Xbox 360 Console
Durabrand 5.1 Surround Sound Computer Speakers Logo
61 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
