Question about Hayward Navigator Pool Cleaner
It wil not go in the circles as before
Mine is only a little over 1 year old and it doesnt turn at all. as a matter of fact it goes into the shallow end and stays in one place. yes, the feet continue to move its like its spinning her wheels...mike
  • 640 Answers
With these automatic pool cleaners, it is probably something easy to correct. First, check your water flow. Make sure that your water flow is correct. Improper water flow can cause problems with the direction in which your cleaner turns. Make sure your shoes and wings are not worn. Clean and check your rear screen. Make sure your cone gear is free and rotates smoothly. Finally, the gear box might need to be replaced.
Posted on Jul 29, 2010
Awd will not go into reverse manual transmission
no year, no joy,
old post.
top inputs are:
year, model body, and sub model, EX ? or?
and country.; not all cars are the same world wide, and this is the www. ! if car is in USA, say so. no one ever has, but do be the first. please.
now a generic answer,
bad M/T clutch.
yes, reverse IS THE CANARY Gear (mine shaft metaphor)
it is a no synchro gear and love to grind, (fact)
#1 top failure for all m/t clutch is.
bad actuator.
from the tip of toe to the bell housing lever, this actuator can fail.
so if the bell lever dont move .75 to 1 inch, the actuator parts are bad, no matter if a cable or hyda, MC/slave.
no matter.
if the actuator is good, then the actual clutch is bad. (locked)
Oct 08, 2013 | Honda CR-V Cars & Trucks
I turn try turning on my xbox but only three of the circles turn on but then the xbox doesnt work
it is the dreaded red ring of death, First thing, is it still under 3 years old? If so, 1 800 MYXBOX,, microsoft will fix it for free, provided its never been opened before
Mar 15, 2010 | Microsoft Xbox 360 Console
My MacBook Pro goes to the grey screen with the
Most likely, you are looking at a corrupt installation of the OS, or a failing hard drive... most likely the latter, unfortunately. Laptop hard drives only seem to last a couple years now, 3-4 if you're really lucky. I would suggest popping in the System Restore Disc (that came with the computer originally) or the OS install disc (in case it has a new version installed than it came with originally) and go to Tools->Disk Utility, and tell it to "repair permissions" and "repair disk", and see if that resolves it. If it happens to, I suggest backing up your data ASAP just in case. More info can be found here on using Disk Utility.
Nov 11, 2009 | Apple MacBook Pro Laptop Computer with...
I have a wide by side maytag plus refridgerator 5 years old-
change the thermostat as well as a technician if i see the heater is ok i change the thermostat and defrost timer together the thermostat  is iffy(if thats even a word) it works sometimes sometimes doesnt unless they obviously bursted but if they are in normal shape doesnt mean they work properly because of the fact that they work sometimes sometimes dont
feel free to ask any questions
Jun 08, 2009 | Refrigerators
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Viewsonic VA720 LCD 17'' monitor LED light blinking, no display
there is atleast a 5 year difference between your computers. Technology has made a huge jump from back then, especially in graphics cards!!! that LCD was probably made after your computer, alot after your computer as a matter of fact. So it is your graphics card. get a new computer, its time to update
Apr 28, 2009 | Computers & Internet
Emerson EWL20D6 TV turns on and the picture goes right back off
Mine is doing the same thing. I talked with a local repair guy over the phone and he says that (obviously) something is malfunctioning in the TV and a sensor shuts it off to minimize the damage to other components. This would be ok if the TV were 20 years old (they used to last that long); however, mine is only 1 1/2 years old and Emerson couldn't give a damn that the TV is a piece of ****. Silly Mimi
Mar 25, 2009 | Emerson EWL20D6 Television
Sony KP-57WS510 rainbows and arches
no the shape doesnt matter as long as the STK numbers are the same. I would make sure that the replacements are origional sanyo ICs as often the cheaper versions do not last very long.
Mar 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Hayward Navigator Pool Cleaner Logo
1,099 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
