Question about Harley Davidson Road Tech HA90 MP3 Player
How to remove starter drive 1988 flh harley - Harley Davidson Road Tech HA90 MP3 Player
  • 91 Answers
SOURCE: illustraited instructions to remove a starter from a Harley soft
no pictures 1 remove the battery neg cable, 2 remove the primary chaincase on left side or bike it is held on with 3/16 allen bolts be ready to catch the oil thats comes out (3/4 of a quart replaces it) 3 remove the small 3/8in bolt that is in the center of the starter shaft (small gear at top of case) 4 go to other side and look at starter see the two large allen bolts at sides remove them now with a little pulling it will squeez out from under the oil tank if not loosen rear oil tank bracket that will help this should help you
Posted on Jan 01, 2009
wd4ity
  • 4565 Answers
SOURCE: 02 flht, new battery, cleaned contacts, no lights, starter relay
The starter relay should not make a sound until you press the starter button. If this is what is happening, replace the starter relay. The little one inch plastic cube cost less than $20 and just plugs in.
Now, you said it was a "new battery". Is this a brand new just bought battery or is one that seems like you replaced it just the other day? I've had people bring me bikes into the shop with "new" batteries only to find them bad. Sometimes a battery doesn't last but about a year in a bike. The reason is vibration. A motorcycle has much more vibration than an automobile and is tougher on the battery. It's best to pull the battery out and have it tested at an automotive parts house. Usually, they'll do this free. Your battery could be the problem. Turn your headlights on and push the starter button. If you the lights go out, bad battery. Good Luck!
Posted on Feb 23, 2010
wd4ity
  • 4565 Answers
SOURCE: i want to install a
Your speedometer is driven by the transmission on your '70 model FLH. But, if you want to put a front wheel speedo drive on the bike, first take a look at a bike that has a front wheel speedo drive. You'll notice that the hub right where the axle goes through has a "notch" in it and the speedo drive has a "tab" that goes into the notch. As the wheel turns, the hub turns the speedo drive. This is how it works.
Now, you have two problems, One is that you need a speedo drive that has the spacer built into it so that you can eliminate a spacer on one side of the hub. Next, is the ratio of the speedo drive. The ratio of the speedo drive must match the speedo or the indicated speed will be incorrect. The speedo ratio for your FLH is probably 1:1 since it's a transmission driven speedo.
Good luck
Steve
Posted on Aug 08, 2010
wd4ity
  • 4565 Answers
SOURCE: I tried to remove the
The plastic tube thing is a screen. If it's got years worth of crud on it or rust in the hole, it will get stuck. The only thing left to do is destroy it to get it out. I have an old dental tool that is shaped like a hook that I use to get them out with. You have to get a grip on it and pull while twisting at the same time. I think Custom Chrome used to sell replacement screens. Maybe the dealer has them but don't tell them what year your bike is. They'll immediately tell you that they don't have it. The same screen is still used in bikes today that have a petcock on them. Personally, I'd rather have a Pingel petcock. They're pricey but it's the end of petcock troubles.
Good Luck
Steve
Posted on Jun 20, 2011
george_karas
  • 220 Answers
SOURCE: 1982 flh hard to start new starter,battery,everything new cranks real hard
Check your conections earth and positive wire,or starter motor brushes need replase.
Posted on Sep 29, 2012
How do I remove the starter on my 1982 Harley FLH Classic
Hi, Chuck for this scenario you will need your service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
2005 Harley Dyna FXDX starter replacement
http://www.carlsalter.com/pdfs/Harley-davidson-1978-80%20FL_FX%20Service%20manual.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak with me personally absolutely "FREE"
Feb 14, 2017 | Harley Davidson Motorcycles
How do I remove the starter on 1982 Harley FLH Classic
Jackshaft removal on 1988 HD fx lowrider
get a clymer manual for that model--library has auto and cycle books also
Apr 09, 2014 | Harley Davidson Motorcycles
Starter solenoid 2004 harley
That is a voltage issue going to your solenoid. If you own a power probe check the voltage going to and from the solenoid. Also you may have a defective solenoid I have seen new ones out of the box be defective so keep that in mind
May 06, 2013 | Motorcycles
Sep 29, 2012 | Harley Davidson FLHTCUI Electra Glide...
Where is my relay starter switch on my 2000 deuce
Well if like mine flh front of bat its with the brake relay they are attached to the frame my knolage is limited to flh 09 & 93...great place to ask is our forum ..you are invited...>> http://www.hdtalking.net/
Aug 17, 2011 | 2000 Harley Davidson FXSTD Softail Duece
I have a 1974 flh 1200 shovel harley i am running a 2 inch primy belt drive with a primary cover over the top i need 2 know how to install a starter motor set up it has a 2 bolt removeble cover under the...
Well, it depends. On some open primary set-ups, you can use stock starter parts and on others you must use their starter plates and the starter they specify. Your '74 model had the Hitachi starter on it and a lot of the belt drive inner primarys and outer clutch shells are set up to use the later Nippondenso type starter. My best advice is to contact the people that made the belt drive on your bike and get their recommendations.
Good Luck
Steve
Apr 23, 2011 | Harley Davidson FLHR Road king Motorcycles
Speedometer cable removale on 1981 FLH
I believe it has to be remove from the front wheel hub end. Front wheel has to be pulled to access the drive.
Jun 16, 2009 | 2005 Harley Davidson XL 1200 R Sporster...
Starter spinning (not engaging) 50% of time
Sometimes they have to have little shims on them so they mesh correctly when they engage.
Jun 05, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Open Questions:
See all Harley Davidson Road Tech HA90 MP3 Player Questions
Harley Davidson Road Tech HA90 MP3 Player Logo
415 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
