I change head cylinder,timingchain,waterpump and it still overheat.it has a 2 speed fan and it does not turn on,only when i turn de air condition.
  • l_a3720 Jul 08, 2010
    my 1998 bmw 318ti it has two speed one to cool the engine and the other speed for the air condition. the fan speed for cooling the motor those not turn on.only the air condition speed turn on.
    i have a 1998 bmw 318ti i change the cylinder head,timingbelt,waterpump,and when i turn on the car it was heating.so i change the radiator fan swicth because the fan to cool the motor was not turning on.the car has a two speed original fan but it only turn on with the air condition.it does"nt want to turn on to cool the motor.
  • 6,826 Answers
So, if you turn the a/c on the fan works but otherwise the coolant temperature sending unit does not turn on the fan for hot coolant conditions?
I would look for a fusible link that supplies the fan for normal cooling without the a/c on.
It's common for technicians to neglect to find the broken fusible links in the wiring harness near the starter of GM cars, anyway.
Stretching the insulation reveals a broken fusible link wire inside the casing. Try to find it that way.
Posted on Jul 08, 2010
    i check power in the wire that connects to the fan plug there is power going thru.
  • Duane Wong
    Duane Wong Jul 08, 2010
    If you have power there, I am not sure why it would overheat then, unless there is a restriction in the passages or a miscalibrated sending unit.
    Brigadier General:
  • 3,092 Answers
If relay and fuse is good, check coolant temp. sensor, will sit on thermostat housing or very close to it, will have two wire connector, disconnect it, if fan come's on, bad sensor, replace it. Also by disconnecting the sensor after repair's have been done the computer will have to be reset, disconnect battery for about 15 sec to reset computer.
    i replace the radiator fan swicth and it still does"nt turn on.why does the fan turn on only whit the air condition.
  • 905 Answers
You didn't mention if the fan was original equipment or aftermarket or not, so will assume both scenarios.
Both:
AC turning the fan on via a relay is a good sign. It indicates that the fan is working and not suspect. The fan relay will be in parallel with thermostat relay. AC relay will likely interrupt the low speed line, and close the high speed line.
OEM:
Check your relays in the relay/fuse box under the hood. Also check your fuses here as well. You will have to obtain a wiring diagram to see if the thermostat of the fan works off the sending unit that also drives the light / guage on the dash. If separate, then replace sending unit for the fan if relay checks out.
Aftermarket:
Your sender / sensor is likely placed in front of the radiator, zip tied more than likely. Using manufacturer manual, manually trip the sender / tstat assembly (usually involves hot water bath, warm water bath, cold water bath) to try and test the sending unit. It it checks out, then direct your attention to the thermostat itself, and/or the relay that it drives.
    whey does the radiator fan only turn on whit the air condition.and it not turning on when the motor is hot.
  • Sheldon Dedek Jul 08, 2010
    Start with a wiring diagram for your car. Find the cooling fan motor, follow wiring backwards. Check the connectors along the way, as well as the relays and fuses as equipped.
Where is the sensor for regulating the temperature R
There is no electronic coolant temp regulator. That is what the thermostat is for as it regulates the flow of coolant between the engine and radiator by opening and closing based on coolant temp. It is mechanical in operation and operates independently of everything else. If it is faulty and is stuck closed or partly closed you will get an overheat condition.
If you still have an overheating problem after what has been done then it could be due to one of these factors if all else is ok...
1. Air remaining in the cooling system retarding coolant flow. It is imperative that all air is bled from the cooling system or you will get an overheat condition cause by air blocks. If you still see bubbles appearing in the coolant this is an indication that there is still air in the system or you may have the issue described in 3. Manufacturer procedures need to be followed for effective air bleeding of the cooling system after radiator coolant has been changed.
2. A partial blockage in the radiator or in the engine retarding coolant flow due to a build up of debris.
3. Combustion gasses leaking into the cooling system via a failed head gasket will cause an overheat condition. This will show up as bubbles in the coolant when the engine is running and can be checked by doing a leak down test on each cylinder. You might also have some coolant escaping into the cylinders and white exhaust emissions can be an indication of this. If you have been running the engine in an overheated condition this can very easily cause a head gasket to fail and a cylinder head to warp or even crack.
Feb 25, 2016 | Cars & Trucks
My 1998 Mitsubishi eclipse GST was overheating I changed out the thermostat and still continues to overheat why?
You have to have a thermostat in the system. Have a compression test done to check for head gasket or cracked head/s. Check the flow rate of the radiator ( blocked cores) check the condition of the cooling fins on the radiator. Check the radiator cap. Check if the fan is working when hot.. If you have a viscous fan hub on the fan then replace it . run the fault codes to check for air/fuel problems . Check for load and speed conditions as high speed when fully loaded will cause your problem . Check that it is actually engaging over drive and not over reving the engine.
Aug 01, 2014 | 1998 Mitsubishi Eclipse
2001 olds silhouette engine overheats
Time for Intake Gaskets and possibly head gaskets, very common problem with these, the intake gaskets go bad and the coolant actually burns in the cylinder and of course the cylinder pumps air into the coolant system because of intake gaskets being bad. :-(
Mar 04, 2013 | 2000 Oldsmobile Silhouette
Overheating I change waterpump, thermostat, flush radiator, change drivebelt, radiator cap radiator hose and it still overheat when i drive it on highway it dont overheat just driving in town it overheats
Two things you can check: First pull your oil dipstick and make sure that the oil is clear and not cloudy or milky, if it is you have a blown head gasket. Secondly if the vehicle has an electric fan make sure that it is coming on. You can do this by starting up the vehicle and letting it warm up for 10min or so or until the guage shows that it is hot. Then look under the hood to see if the fan is turning, you may have to watch it for a few min because they will cycle on and off. If the fan doesn't come on, that is why it overheats in town because it is not getting enough airflow across the radiator. If the fan does not come on you can start troubleshooting it by checking the fuses and relays in the dash and under the hood. If the relays and fuses are good and the fan still won't come on, with the key on and engine off, carefully wiggle the wire that goes into the fan, these sometimes make bad connections, but again be careful because if that is the issue the fan will begin spinning so watch your hands and fingers.
Sep 22, 2010 | Chevrolet C1500 Cars & Trucks
Overheat 2001 hyundai tiburon
Only 2 parts remaining are the thermostat and waterpump. Always start with the thermostat when diagnosing an overheating problem. If the car is overheating constantly under all conditions and coolant is backing up into the reservoir, it's very likely to be the thermostat. If it only overheats at low speed or idling, it's more likely the waterpump.
Aug 11, 2009 | 1998 Hyundai Tiburon
I have a 98 Accord that continues to overheat. I
Definate cylinder head gasket or cracked cylinder head. Compresion from the engine cylinders getting into the coolant system and blowing out the water. But what you have done so far is money well spent as something had to cause the overheating to begin with so fixing the cylinder head problem would have been one problem solved but not a complete fix.
Aug 11, 2009 | 1998 Honda Accord
Air cool when driving, when idling gets warm and car overheats
Take a look through your front grill and see if there is alot of bugs,dirt,etc. blocking the cooling fins of the condensor and radiator. If so try rinsing them with a water hose, or air pressure. Some cleaners work well also,like " Simple Green " or gunk degreaser. Catch the fluid in a container and dispose of properly.
Jul 29, 2009 | 1998 Ford Mustang
Replaced waterpump, still overheating lights comes on
Check to see if there is water in the oil...If there is water in the oil then it could have a head gasket problem..Did you ever replace the thermostat? If it is stuck then it would also cause overheating...Excessive exhaust backpressure because of a clogged catalytic converter could also cause overheating..Also check belt tension and condition. A loose belt that slips may prevent the water pump from circulating coolant fast enough and/or the fan from turning fast for proper cooling...Another thing it could be is a faulty Water pump -- Any wobble in the pump shaft or seepage would call for replacement. In some instances, a pump can cause an engine to overheat if the impeller vanes are badly eroded due to corrosion or if the impeller has come loose from the shaft. The wrong pump may also cause an engine to overheat. Some engines with serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with ordinary V-belts... Also check the Fan -- With mechanical fans, most overheating problems are caused by a faulty fan clutch, though a missing fan shroud can reduce the fan's cooling effectiveness by as much as 50% (depending on the fan's distance from the radiator) which may be enough to cause the engine to overheat in hot weather or when working hard.
Mar 18, 2009 | 2005 Chevrolet Impala
1990 ford ranger is overheating
If the cooling system has no bleeder valves to vent air, you may have to temporarily loosen a heater hose to get all the air out of the system...Also check to see if there is water in the oil...If there is water in the oil then it could have a head gasket problem....Excessive exhaust backpressure because of a clogged catalytic converter could also cause overheating..Also check belt tension and condition. A loose belt that slips may prevent the water pump from circulating coolant fast enough and/or the fan from turning fast for proper cooling...Another thing it could be is a faulty Water pump -- Any wobble in the pump shaft or seepage would call for replacement. In some instances, a pump can cause an engine to overheat if the impeller vanes are badly eroded due to corrosion or if the impeller has come loose from the shaft. The wrong pump may also cause an engine to overheat. Some engines with serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with ordinary V-belts... Also check the Fan -- With mechanical fans, most overheating problems are caused by a faulty fan clutch, though a missing fan shroud can reduce the fan's cooling effectiveness by as much as 50% (depending on the fan's distance from the radiator) which may be enough to cause the engine to overheat in hot weather or when working hard.
Oct 20, 2008 | 1998 Oldsmobile Bravada
1994 bmw 318i
Where is the water pump on 94 BMW 318, Is it behind the Fan or a seperate unit. is it easy to replace?
Jul 13, 2008 | 1996 BMW 318
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
