Question about Dell E177FP LCD Monitor
Have a dell e177fp monitor. When I power on it only displays for 3 seconds and shuts off. Green power light remains on.
  • 11,361 Answers
You need to check the voltages and components in the power supply/inverter board first. It should have 5vdc for logic and 12~16vdc for the backlight innerter circuits.
There are three version of the boards for this model.
http://lcdrepair.us/Invpowersupply.html
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 09, 2010
The monitor wont come on.i noticed the power button has been pushed inside the monitor and i need to know if i can disassemble it to get i tout without hurting the monitor
The E177fp and E197fp are identical units other than the size of the display panel. Here is a link to a repair guide for the E177fp that has videos showing how to open the unit. It should help you get your open.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-e177fpf-lcd-monitor-with-power-issues/
Nov 07, 2012 | Dell E197FP 19 inch Flat Panel LCD Monitor
Backlight problems
Yes,
If the capacitors in the power supply are bulging that indicates that they have failed internally and need to be replaced. That would cause the back light inverter to shut down just like you are having.Replace the capacitors and you should be good to go.
BuddyMc
Jul 23, 2012 | Dell Computers & Internet
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
Apr 04, 2011 | Dell E177FP LCD Monitor
When turning on the computer from standby the computer turns on fine however the screen remains black and the power light is green. I need to reboot the system altogther in order to get the screen to boot...
Please update the drivers for your computer from support.dell.com and also update your windows. This problem should get automatically rectified after the update.
Feb 03, 2011 | Dell E177FP LCD Monitor
Dell monitor E177FPc - light comes on green but immediately turns steady amber and screen is black. this has happened before and I can't remember how we fixed it.
Dell monitor E177FPc - light comes on green but immediately turns steady amber and screen is black? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SED2H 715G1492 2 FR Dell ADTV1742SED2H Power Supply Backlight Inverter...
Nov 15, 2010 | Dell E177FP LCD Monitor
You probably have failure in the inverter circuits due to shorted transistors, bad solder joints, bad caps. Please see my pictures here so you will know what to look for inside.
Replacment board:
http://www.lcdrepair.us
Please post back so it may help other people with the same problem.
Apr 09, 2010 | Dell E177FP LCD Monitor
Monitor does not want to wake up. Pressing the yellow rest switch the button goes green for less that 3 seconds, then goes yellow.
try unplugging your computer and your monitor for about a minute and turn back on. Then see if it works, Good Luck ;)
Nov 12, 2009 | Dell E177FP LCD Monitor
Dell Monitor won't stay on
When it goes black, does the power buton stay green or is it orange? If it's orange, the power supply/inverter is your main culprit. If the power button stays green, it sounds like the backlight for the display is bad. Either way, unless you have parts for the same monitor laying around to swap out, you're due for a new monitor. The good news- with the economy in the tank, you can search online and find some reputable vendors selling nicely sized screens for less than $100! Heck, I've even seen a 22" for $129 (once but it was there).
Sep 23, 2008 | Dell E177FP LCD Monitor
Monitor won't turn on without help.
Do you have a second monitor or can you borrow one to check if the fault lies with the monitor or the PC?
If the monitor is at fault then there is not much you can do yourself. I suggest you contact Dell and get them to replace it under warranty. Most LCD monitors have a 3 year warrantly, at least they do in the UK.
cheers
Aug 04, 2008 | Dell E177FP LCD Monitor
Dell monitor E177FP LCD Monitor
This is normal, typically you must press the power button (on the monitor) to turn it off.
Mar 09, 2008 | Dell E177FP LCD Monitor
Dell E177FP LCD Monitor Logo
205 people viewed this question
Alun Cox
