Question about DeLonghi Pinguino PAC-02 Air Conditioner
My delonghi pinguino pac 2 has the caution light on after 20mins of being in operation we cleaned the filter and emptied the water reserve. Why is this happening?
SOURCE: FE Light
You need drain the water and then function normally.
Posted on Oct 02, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: delonghi pinguino pac l90 manual
Here you go!
http://www.manualnguide.com/download/manual-guide/delonghi-pinguino-pac210-portable-air-conditioner-owners-manual.html
Posted on Aug 19, 2008
  • 66 Answers
SOURCE: DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Posted on Feb 19, 2010
  • 66 Answers
SOURCE: i own a delonghi pinguino eco PAC T120 and when i
Probably, the
"ft" means to check the filter. If your filter has not been cleaned in a while, it cannot breathe,and operate properly.
  • 5 Answers
SOURCE: Looking for a user manual
here ya go.... http://www.sylvane.com/images/prodphoto/de1050/PAC-A120E-usermanual.pdf
Posted on Oct 09, 2010
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
I own a delonghi pinguino eco PAC T120 and when i switch it on it shows 'ft'on the screen. it doesnt turn the air on. what can i do?
Probably, the
Dec 22, 2009 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Empty wateron DeLonghi Pinguino Pac L 90
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Sep 08, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
K 900, pinguino
I had the same problem with my Delonghi K900.  I have an extended warrantee for both my Delonghi air conditioners.  It was taken into the shop and discovered that the hose that allows the water to drip into the collecting tank was clogged with dirt and dust. I find it is a good idea to have them cleaned and checked once a year, especially if used often. For under a hundred dollars, I have a warrantee that will last until the year 2010.  Sears offers warrantees for any home appliance, even if it wasn't purchased there. Taking the air conditioner apart yourself can cancel any warrantee on them machine. Hope this helps. Trisha
Jul 27, 2008 | DeLonghi Pinguino PAC-77E Air Conditioner
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Jan 10, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
FE Light
Sep 23, 2007 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguino PAC-02 Air Conditioner Logo
61 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
