Question about Kenmore Dishwashers
Kenmore elite dishwasher drains intermittently
Dishwasher will drain ok for weeks then stop
you can hear it trying to drain
everything else works
we have hard water and a softener
4 Suggested Answers
reg501
  • 413 Answers
SOURCE: Kenmore Ultra Wash Dishwasher does not drain
Some Kenmore DW have a check valve attached to the sump that may have a blockage. Remove toe panel, look for a long, white, plastic fitting attached the front, right side of the sump. Remove the drain hose from the valve. Unscrew the valve from the sump and inspect for debris inside the valve.
Posted on Jun 14, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
Kenmore elite dishwasher 665.12793k311 will not drain automatically. Drains fine when drain button is pressed. Has been running perfect for the past 14 months then all of a sudden stopped draining aut
Wow, that's interesting! I would have guessed the control module (control circuit board) too. But, once upon a time, I encountered a similar situation, and the problem turned out to be the drain pump! It seems like that after the dishwasher ran in the main cycle (where the heater is used to heat up the water), the heat somehow made the drain pump stop working! I don't know if it made the motor wires expand and break a connection, or if the heat made the seals of the motor expand or somehow impeded the free-turning of the motor, but replacing that drain pump fixed the problem! If you want to try this, I would really like hearing back from you on whether or not that fixes your problem. Good luck!
Jan 16, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
My Kenmore dishwasher leaves water in the bottom of the dishwasher. Is that OK? I notice the water when I clean out the bottom tray.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 18, 2011 | Kenmore Washing Machines
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite Mdl:665, Same probelem
if ur unit drain pipe is connected to air gap mounted at the sink then open up the cap of air gap and see if some food debris is stuck there?debris will rectrict the flow of water back to food disposar and water can remain in the unit.
Aug 21, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore Elite model 665.17052400 dishwasher will not drain
Check disposal to see if d/w knock out was removed form disposal. If so check drain hose for kinks or restrictions.
Ie unistally hose from disp and see if d/w will drain into bucket. IF not uninstall d/w and check for kinks.
Jul 18, 2009 | Kenmore 15899 Built-in Dishwasher
Does not drain
The light buzzing of the motor doesn't mean the pump is in good condition and actually is being driven by the motor, in fact a seized synchronous motor can make a convincing buzzing sound and not burn out for a long time. The pump intake could be blocked...
If the symptoms indicate there could be something wrong with the pump then visual confirmation is required and not merely the assumption.
Jun 18, 2017 | Kenmore 24 in. 17052 / 17054 / 17059...
Keeps flashing clean Kenmore dishwasher 665.17019401 need a new owners manual
i was trying to install my kenmore elite 665 dishwasher but i cant find the plug do they come with one? or were do i hook it up?
Sep 22, 2007 | Dishwashers
Dishwashers Logo
61 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
