Question about GE DCSR483EA Electric Dryer
The start button no longer works. When you push it in it sticks and the dryuer will not turn on.
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryerThe start button no longer works. When you push it - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryerThe start button no longer works. When you push it - 2_bing.gifng
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 12, 2010
ROKU STICK IS NOT STARTING AUTOMATICALLY.
Check plug in roku stick and in electrical outlet for a good connection pull out and push back in..Their is a small reset button on ROKU,push it ,it will then show a blinking white light,if not you may have a bad roku stick.
Hook up ROKU stick BEFORE you put batteries in remote,after you put in batteries you will have to push button near batteries.
The remote should start blinking a green light this means it is trying to pair up with roku stick.If it does a purple sceen will appear on tv.Push home button remote and tv should give you a code.This code has to be entered at ROKU site link on computer.
Jan 29, 2016 | Roku Streaming Stick
Husqvarna viking designer 1 embroidery machine. Touch screen icon for disk and usb loading is not working but everything else is.
Sounds like a loose cable or the USB drive has gone bad. The Designer 1 is notorious for having a delay in reading USB sticks. You will probably have to wait a full minute from the time you turn the machine on until it will read the stick. The Viking stick is the only 1 Viking recommends for use. But customers have been able to get other sticks to work. Get the smallest memory stick (storage capacity) possible if not a Viking stick. I have gotten the Office Depot brand and the EMC brand to work haphazardly. Also make sure the stick has been formatted and prepared to work with the Designer 1 machine. There is a menu structure that has to be used for the stick. However a quick way to check if it's the stick and not the machine is to put it the stick in the machine with the power off and turn the machine on as though to update it -
Push in firmly and hold the start/stop button and the stitch re-start button at the same time. See illustrations. With both of these buttons firmly depressed, turn the Designer I ON
If the machine says 'file not found' it is reading the stick. If the machine just goes to the regular sewing menu or says Disk Not Accepted it is a problem with the machine USB port.
Suggest having it serviced by an Authorized Viking Dealer. You can find your nearest dealer at the Viking Website - http://www.husqvarnaviking.com/us and click on Locate a Dealer.
Sep 26, 2013 | Husqvarna Viking Designer 1 Embroidery Arm...
Can not get toyota cororlla out of park. would not turn over. battery good
Start the engine, depress the brake pedal, press the oval push button attached to the upper side of the gear lever stick and shift the lever to R, N, or D. It should work. If not check the following:
- Push button mechanism and the solenoid for malfunction.
- Brake switch assembly.
- Wiring harness.
You can also release the gear lever by pressing the small red button located on the base of gear lever stick. Simultaneously press the small red button and the push button of the gear lever stick to get it out from P.
Aug 05, 2013 | 1996 Toyota Corolla
I own a mad catz n64 controller and any time i push or hold any button (b,a, cs) it makes the character move slightly but endlessly to the right side, the control stick works fine, i only got this problem...
To remedy this, simply don't move the analog stick when powering on the system. When the system turns on, however the analog stick is set to be the default center so if it is moved, it is assumed to be the normal center position. If you have accidentally moved it while powering on the system, you can reset it but letting the analog stick reset to center and then press and hold START, L and R at the same time for three seconds.
Jul 18, 2011 | Nintendo 64 Console
Starter turn procket ok chain ok .engin dont turn .in back off the motor noise chaine turn in empty...
If your starter motor is running and the engine is not turning over, then the problem is in the one way clutch attached to the fly wheel. The solid steel cylinders are sticking in the clutch and are no longer round. Also on the side of the large starter gear is a shiny cylindrical surface that sticks out of the side of the gear, if this surface is not perfectly smooth and round , the small round cylinders will not grab and turn the large sprocket to turn over the motor. You may have to replace the three cylinders and the starter gear so the engine will turn over and start when you push the button.
Dec 28, 2010 | 1981 Honda GL 1100 Gold Wing
Both key fobs for honda pilot 2006 no longer works. Do I need new keys or is it something internal such as a fuse?
First thing, does the red light on the remote light up when you push any of the button
if no, then replace battery inside remote
if yes, then try repograming the remote to the car again.
-Have both remote ready. fob#1 and fob#2 (doesn't matter which one is #1 or #2)
-each step has to be done within 5 sec or it will not work, but don't do it super fast.
1.turn key just to the "on" position (not starting) and push "lock button " on fob#1 once and release
2.turn key off
3.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
4.turn key off
5.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
6turn key off
7.turn key just to the "on" position (not starting) and push "lock button " on fob#1 twice (if you only have one fob, then stop here and go to step 7)and push the "lock button" on fob#2 twice.
8.turn key off and remove key from ignition.
if you did it right, remotes should work again.
good luck
Dec 17, 2010 | Honda Pilot Cars & Trucks
1979 CX500. When you push the start button why does light dim
The starter button when pushed in half way turns the power off to the lights so more electricity can be used for powering the ignition and starter at the same time. If you press lightly you can turn off the lights with out engaging the starter. Pressing all the way down engages the starter. The button is a two position switch. Carefully take it apart , clean it and put it back together and you may fix the problem.I have three old Honda motorcycles that all have right hand switch assemblies wired to them from other bikes (Because the original was no longer available) You should be able to rewire any Honda two cable switch too work on your bike.
May 06, 2010 | 1979 Honda CX 500 A
Ariston LD 87 Demo displaying and wont run
I pushed the "power button" and the "start button" together for some seconds, and then the dishwasher was ok, and didnt run the Demo longer.
Jan 24, 2009 | Kenmore 17024 Built-in Dishwasher
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Controller problems
Have you gone back and tried that game again? And were you using one (or both) of the two sticks to move in that game, or were you using the directional pad.
The dual shock controllers on the PS2 have a small, easily overlooked button between the two sticks. It has a red light directly above it. If you push that button, the light will switch on and off. When the light is on, you can use the sticks in pressure sensitive mode. For example, if you push the stick a little, your character may walk, but if you push it further in a direction he will run instead. It's used differently in different games. But certain games won't operate unless that feature is either on or off (again, it varies by game).
My guess is that the button was accidentally pressed while you were playing, and suddenly the controller didn't work. But when you switched games, most games will turn the light on when they start up, if they need it, so the problem corrected itself.
-John
Feb 06, 2008 | Sony PlayStation 2 (PS2) Console
GE DCSR483EA Electric Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
