Question about Weather King 10AJA2501AH Air Conditioner
I have 2 Weather King units model numbers 10AJA2501 & 10AJA6001 and am trying to determine the sizes and SEER ratings of each
  • 455 Answers
Hello Larry Both units are 10 SEER.Standard rating ,not efficent units.JA25 is a 2 ton unit,JA60 is a 5 ton unit.Thats 24,000 BTU & 60,000 BTU.I hope that helps.
Posted on Jul 08, 2010
WHAT IS THE CAPACITY OF 10AJA6001???
Check the Weather King website. There should be a tag plate on the unit.
Home Heating and Cooling Products WeatherKing Where Home Comfort Rules
or anything here that might help
Weather King 10AJA6001 specs Google Search
Dec 08, 2017 | Cars & Trucks
Trying to determine what size capacitor my unit C1048BBD1VF uses for my AC unit. Is it larger then a 45 amp? Replace it with a 45 and you can hear it try to turn on but it won't.
capacitors are rated in microfarads or picofarads and not amps
capacitors are used to provide a boost voltage to start motors and then to keep them running
Amps is current flow so what ever you replaced was the wrong unit.
on the side of a capacitor will be voltage rating (110-115-220-240 etc and a number 45 -55 60 uf etc
it will have either 2 terminals or 4 terminals connected as pairs
from what you describe it is a capacitor problem
May 26, 2016 | Airwell Fedders Fedders C1048bbd3vf 3...
Comfortmaker 10 HVAC output size?
Comfortmaker 10 means simply it is a 10 SEER system. Unable to determine the OUTPUT size without the Model Number. Go to the Outdoor Unit Nameplate and locate the Model No. Here is an easy way to determine the "SIZE" of the "Comfortmaker 10 HVAC" Systems:
Model No.: OUTPUT Size (Nominal Tons of A/C):
NAC015 1.5 Ton Unit
NAC024 2.0 Ton Unit
NAC030 2,5 Ton Unit
NAC036 3.0 Ton Unit
NAC042 3.5 Ton Unit
NAC048 4.0 Ton Unit
Aug 30, 2014 | Heating & Cooling
Trying to get info (tonnage seer rating) on a weatherking mod# 10ajb48a01 condencing unit to find a matching evaporator coil and cannot find anything on internet
This is a 4 ton model condensing unit. You can go up 1/2 ton for the evaporator, meaning a 4 1/2 (A) coil will work just fine and allow a bit more cooling capacity.
Sep 10, 2011 | Weather King 12AJA4801AH Air Conditioner
Where is my manual reset button on my weather king condensor unit 10aja2501?
most likely your unit is low in freon and if your unit has a low cut out pressure switch you don't have to reset it because they have an automatic reset which happens when the pressure inside the unit goes up.
Jul 12, 2010 | Weather King 10PJA2501AH Air Conditioner
How many tons is my condensor with model number 10aja6001?
Hello
Find the btus, 6000 btu is 1 ton. So 12000 is 2 tons.
Most home central units are 3 to 4 tons.
May 05, 2010 | Weather King 10AJA6001AH Air Conditioner
Need to have an idea of the number of kw needed. max load normal
Most central air units depending on age and SEER rating will draw 220 volts of power and anywhere from 3 to 30 amps of power while operating. calculating a kilowatt draw would need to be done by your power company most likely. Also try looking at your power bill or calling the power company and asking for your detailed usage on a daily basis most of them print it on the bill I think and look at it for a time of year that you are sure it was warm and the system was running. Obviously the system will draw much more power the hotter it is outside so if you are needing an exact number for calculating a use for something like a generator to power it you should always go with a little extra. good luck hope this helped.
Sep 20, 2009 | Weather King 10AJA6001AH Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
836 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
