Question about Harman Multimedia HS 300 System
HS 300 firmware upgrade troubleshoot
Hi, I did a firmware upgrade for my HS 300. After it completed, I switched off the system as instructed and switched it back on but the display from the system went completely. The message on the TV is "No Signal". Could you help me out with this?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Harman Multi... Master
  • 924 Answers
If you did nothing but upgrade the firmware, I'm sorry to say, an issue occurred during the upgrade. The only way to fix this now, is to replace the microprocessor(computer) IC that was damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Dec 09, 2013
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
Install XF2 Firmware V4.10
After you have downloaded the file "install.img" from lge.com,connect it to your TV,go to Settings,then System Upgrade,press OK to show the sub items of System Upgrade, choose "Cancel" to abort the operation and choose "Upgrade" to upgrade the system firmware. Afterward,
the system will reboot and the firmware upgrade page begin to show. After firmware upgrade completed, the system will reboot and show the language selection page.
Sep 06, 2012 | LG (HXF1N50SB) 500 GB USB 2.0 Hard Drive
I just purchased a Canon ELPH 300 HS camera. I didn't receive a printed User Guide to take with me on my trip. Where can I send for one? How soon would it get here? Best Buy is not helping.
Check the next link for Canon PowerShot ELPH 300 HS (also called IXUS 220 HS ) Digital Compact Camera PDF format Operating Instruction Guide / Owner's Manual / User's Manual Download: canon-powershot-elph-300-hs-ixus-220-hs-manual
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | Cameras
Samsung sf-650 intermittently sends a blank page
Print configuration report "Menu>Reports>Configuration/System Data"
Check the firmware version. 1.07 or lower is likely to have this problem
Upgrading the firmware is quite simple.
Get the update from samsung website Samsung.com>Support>Search Box "SF-650">on product support page find tab "firmware" and download upgrade file.
If you feel competent to do the upgrade (read the instructions in the txt file twice) do it.
Be aware that the upgrade will likely want to do a memory clear once it is complete so you will loose address book etc. Also do not power off unit during upgrade or you will damage the firmware and possibly make the unit unusable.
Hope this fixes the issue.
Feb 21, 2011 | Samsung SF650 Plain Paper Laser Fax
Hi, The USB external disks greater than 250GB are not getting recognised in the system. Model : HS 300ME USB: tried western digital, segate. Regards, Utpal
The unit is apparently not designed to address any drive larger than 250MB. You might look on Harman's website and see if they have a firmware update for this. For more information, please visit my website at audioserviceclinic.com. Thank you.
Aug 21, 2010 | Harman Multimedia HS 300 System
BlackBerry Curve 8320 will not connect with HS-100W
If it's any consolation. My BB 8820 connects to my Zyxel NBG-460N, but after a few minutes the connection just dies (the BB still shows its connected to the WiFi, tries to use it and can in fact send packets out, but it does not receive anything any more). The router has gone through 3 firmware upgrades so far and no solution. It's also causing trouble with some USB WiFi sticks when the SSID hiding is enabled.
In short: I believe ZyXEL's WLAN support is simply broken, and you'll have to buy a WLAN AP from another manufacturer.
Oct 04, 2009 | Zyxel HomeSafe HS-100W Wireless Router...
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
Charter High-Speed Cable and the BEFW11S4 Version 4
To resolve this problem, you will need to upgrade your router's firmware. Click ftp://ftp.linksys.com/pub/network/befw11s4_v4_v1.50.14_code.bin and download the file to your Desktop or My Documents folder (the link is to v1.50.14 firmware code). Once the BIN file has been downloaded, follow these instructions to upgrade the router's firmware: NOTE: Before upgrading your router's firmware, please make sure that the procedure is being performed by a computer that is connected directly to the Router with an Ethernet cable and not a wirelessly connected computer. Accessing the Router's Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Upgrading the Router From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. Click on the Administration tab. 2. When the ?Administration? page loads, click on the Firmware Upgrade sub-tab. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. If the logo matches the image above ("Linksys"), follow these steps: 1. Click on the Help tab. 2. When the "Help" page loads, click on the Upgrade Firmware link. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. After completing the steps above, the router's firmware should be upgraded successfully.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Harman Multimedia HS 300 System Logo
453 people viewed this question
Top Harman Multimedia Audio Players & Recorders Experts
Steve
berggei
Are you a Harman Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
