Question about Sharp AF-S125MX Thru-Wall/Window Air Conditioner
Thermostat will not go below 74 previously would go to temp set.
Turns on right away, but when it goes down to 74 shuts off and comes back on at 82.
  • Sharp Master
  • 43,501 Answers
Once it shuts down it will stay off for about five minutes to protect the compressor...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
RERFIG TEMP PROBLEM
the problem is with the lighitng, you should change that part that when you open the refregirator it turns on, after you change it the temrature will come back. Hope this helped you.
Feb 24, 2008 | Refrigerators
Kenmore wall oven model 911.4088816
i believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Dec 18, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Ritetemp model 8050c if i set temp. To 74 it goes up to 82 and beyond in minutes or hours. How can i set it to stay where i want it
While in heating or cooling press the temp hold button behind the door. Hold will be displayed rather than p1, p2 p3 or p4.
Jun 14, 2017 | Heating & Cooling
Series 48000 with heat pump we don't want this to run all the time will the heat shut off when it reaches a certain temp also if the power goes out does it come back on automatic we want to heat our place...
Not sure about your particular make and model, but air conditioners are designed to work with a thermostat to control the functions. A properly functioning thermostat will stop the compressor when the set space temperature is satisfied. When the space temperature falls below (heating) the set temperature, the thermostat should turn it back on. In the event of power failure, an electronic thermostat probably will not operate at the previous set temperature when power is restored, but maybe at a higher temperature (but will work).
Dec 05, 2013 | Coleman Mach 15 Air Conditioner
I have a White-Rodgers programmable thermostat. I have it set to go to 74 degrees at 11:00 PM. It has started going to 74 at between 10:00 and 10:30 PM. If I press run it goes back to the daytime temp...
Hello I assume its cooling program.Probally the thermostat has a recovery mode.In another words the thermostat will come on EARLY to make sure you are at (74*f at 11:00).Maybe try 11:30 start time and see if that helps or disable energy recovery mode.
Jun 17, 2011 | Heating & Cooling
It making a humming sound and the fan is going around slow the temp in home is 74 the set temp is 65 so it should not be running what could be the problem ruud upka-035jak is model
If you are running A.C.,and the T-stat is set at 65,and the room temp is 74,the A.C. will run until the temp goes down to about 65 or so.Turn T-stat to 76 and the unit should shut down. Also,check furnace filter for dirt, and check condensor unit coils and see if they are dirty.If condensor coil is dirty it cannot breathe properly. That will cause the compressor, and the blower motor to overheat.Wash cond. coil down with water hose to clean .Start at top of coil and go sideways,slowly going down.
Feb 23, 2010 | Ruud Matching Split Air Conditioner
My thermostat will not change the temp when trying to change
tHE TIME PERIOD SETTINGS ARE ONLY TEMPORARILY OVER RIDDEN. oNCE THE TEMP YOU SET IS REACHED AND THE UNIT SHUTS OFF IT DEFAULTS TO THE PERMANENT SETTINGS ON THE CLOCK.
Jun 05, 2009 | Honeywell Programmable Thermostat Heater
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
I set temp to 74 and stop at 70 and decresing.
Sounds like the variances are not set right. if I am understand you. You set the thermostat to 74 and the heater shuts off at 70? If that is correct then the variances are wrong or you have placed the T stat in a bad location where it is getting heat from a vent, wall where there is a appliance or in a very drafty location
Feb 10, 2009 | Hunter Fan Company 5/1/1 Programmable...
Sharp AF-S125MX Thru-Wall/Window Air Conditioner Logo
136 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
