AC not working. Comfort aire model. QUE30-1C. Checked fuses they are ok. Thermostat seems to be working. What else can I check?
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Holiday Rambler Vacationer RV duo-therm comfort control doesn't work
see if 12 volts from thermostat to air unit if you jump thermostat and voltage to unit possible bad motor
Apr 05, 2017 | RVs
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
There is no power to AC when I plug it in. I checked the fuse box and everything seems to be working.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 30, 2010 | Comfort-Aire CS-101A Air Conditioner
Ac in 2004 sierra is blowing hot air and the selector buttons for
Hi,I am going to try and help you.This could be a problem in the ac system not allowing the ac system to operate.This could be freon loss,But needs to be checked out by a ac mechanic to tell exactly what is causing the problem.The ac may have to be reset,if this is the case.If I can be anymore helpful,please feel free to notify me.ronieon@gmail.com.
Jul 12, 2009 | 2004 GMC Sierra
Power outage/AC not cooling
ok if you have split system if indoor fan runs then transformer is working you have 2 breakers 1 for indoor and 1 for out door also disconnect at unit may have fuse in it if all seem ok remove side cover and look at capacitor if sweeled up bad take an insulated object and push in contactor if runs check for 24v from common to yellow stat wires also look for reset button next to freon lines hope this helps
Jun 14, 2009 | Whirlwind FH-778 Air Conditioner
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
Heater and air conditioner aren't working
first check and if the thermostat is working. take it out put it in hot water. the thermostat should open up. also put a temp gauge in the hot water so you know at what temp it opens up. start there. dont forget theres more fuses under the hood for the ac unit
Dec 18, 2008 | 1994 Subaru SVX
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
