My screen keeps skipping , rolling and going in and out
Try to restart and make sure that your antivirus is updated and and working properly, and make a computer scan. Your computer might be infected. If so be careful as the antivirus may ask for your permission to whether delete, disinfect, or to put in quarentine. And you should look care fully at the details or route of the file to make sure, for example, that you don't delete a sistem file but disinfect it.
Well I hope it helps.
Posted on Apr 19, 2008
Txl3276 does it have a memory battery to keep settings
Its main system memory IC is faulty. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 21, 2015 | Samsung TXL3276 32" TV
Screen keeps rolling on dsc-w80
Can you please be more spesific?
heres your user manual
http://www.docs.sony.com/release/DSCW80.pdf
-comment or reply will send me a message
-reposting the problem means rejecting the current expert and calling in another.
Looking forward to your response.
Thanks,
Ekse
Jul 07, 2008 | Cameras
Zigzag stitch problems on brothers pc-420 sewing machine
Sewing machine skips stitches
1.needle inserted incorrectly
flat side of the needle faces the shaft
round needle
groove of needle faces away from the shaft
Correct needle insertion is mandatory for proper use
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle.
Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem
8.size of needle & thread & the fabric are not compatable
Mar 30, 2012 | Brother PC-420
Lost remote ans ended up deletde ch 3 what can i do,plus thr tv is rolling picture.can this be resolved without a remote
rolling of picture can be controlled by v.hold or vertical hold on your tv. some tv has has this control on the back side. if the control is there & it is not controlling the rolling of picture, that means the control is bad & needs replacement. to get ch 3 back: go to menu & try to find SKIP function, go to ch 3 & put off SKIP.
Aug 25, 2011 | Televison & Video
I can hear others but cant talk out
I may need more info then provided.
There are a few reasons this may be. If you are new to CB this could be 1 possible reason.
You may be experiencing "Skip". Skip is when the ionosphere is charged with energy by a solar flair(s), which causes radio waves to skip and bounce across them. Normally radio waves are line of sight. Meaning, the curvature of the earth prevents radio waves from traveling extreme distances. When skip is "Rolling" (meaning, skip is happening) the radio waves can bounce and skip around the earth and travel hundreds and even thousands of miles further then the typical 8 to 12 miles they normally travel.
There are a lot of guys out there that run "big power" using linear amplifiers to boost the power of their radio into the thousands of watts. They are more likely to "shoot a skip" much further then a "barefoot" radio. (radio alone with no amplification). Also they are very likely to key over lower powered signals.
So what may be happening is, you are hearing a CB operator(s) hundreds or thousands of miles away, who is running a lot of power. You can hear him because he is running a lot of power, so his signal goes very far.He cannot hear you either because your signal is not strong enough, or other CB operators running a lot of power are keying over you when you try to talk.
This is very like now because we are going into a solar flair cycle which lasts about 11 years. There will be an extreme amount of solar activity, so you will often hear skip rolling. Recently, in the past few months it has been going every day. Nights are usually quieter due to the fact that the sun is not out, although there may still be some skip going on.
You may like to try to shoot a skip. It will be hard with a barefoot radio on a busy channel. You may have luck in the evening on a quiet channel you hear a person or 2 talking. Try talking to them and ask them what state they are in. You may be surprised by what they answer.
If the issue is not skip, and you know who you hear is local, then there may be a few reasons.
You antenna may not be tuned to best SWR. Refer to your manual that came with the radio, and antenna under SWR.
If you ANT light comes on when you key, you have a bad antenna problem for sure.
If you have been keying it with that light coming on, and it has worked up until this point, you may have blown out your final transistor. Then the radio needs repair.
Your mic gain may not be high enough. For a stock CB you might as well turn it all the way up and leave it.
Jul 31, 2011 | Radio Communications
The driver's side power window is skipping or
Most likely the rail has come loose inside the track you can drill a hole and put a #20 nut and screw in it to hold it tight so it won't move the track is the most common thing to wear out on the window. once you repair it it should be fine check all four corners the most common break is in the lower right side looking at the door with it open. Also the track will come loose as well and that can cause you the same problem, with the cover off the door operate it so you can determine which area it is jumping from and then fix it. also lube the tracks with synthetic grease to keep it from being hard to roll up also lube the rollers in the bottom of the track.
Jul 17, 2009 | 1999 Chevrolet Blazer
The screen keeps rolling
I had the same problem.. had to change my video cord that goes from player to TV
Mar 25, 2009 | JVC XL-MV303 CD Player
WHAT CAUSES A COMPUTER SCREEN TO KEEP ROLLING
sounds like either the monitor or internal video card is dying, the rolling would be the equivalent of vertical hold button on a old crt tv
Mar 09, 2009 | HP Pavilion dv9000z Notebook
Display screen is rolling
a few possibilities =
lcd damaged
main board damaged
or loose connection.
any of the three needs to be repaired.
sorry for the bad new :(
Feb 19, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Screen keeps skipping
if it is progressive scan, one of three cables or inputs may not be functioning.
Jan 14, 2008 | Cyberhome CH-DVD 300 DVD Player
Open Questions:
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
