Question about Brother HL 1440 Laser Printer
Changed the drum & ink cartridge in HL-1440-ink bleeds on edge
I have a laser printer HL-1440, changed the drum and ink cartridge two weeks ago, when printing now the right vertical edge of the paper is covered in black ink. Does this sound like a defective ink cartridge? Drum problem?
    Brigadier General:
  • 3,614 Answers
This problem is often caused by spilled toner. Open the printer, carefully remove the cartridge, and give it a few bursts of compressed air. Often running several pages or type through will also fix this. If it persists, replace the toner cartridge.
Hope this initial info/idea helps. Let me know for any clarifications.
Posted on Jul 08, 2010
  • DetPete May 25, 2011
    Mine did the exact same thing. I cleaned the corona wires and it fixed the problem. They are located under each toner cartridge. Details can be found on the Brothers website under troubleshooting.
Where is the cartridge on a brother laser printer HL-1400
I don't see a Brother HL-1400 on their site. However, there is an HL-1440 which uses the TN-430 (regular) or TN-460 (high yield) toner cartridges. This printer also takes the DR-400 drum unit.
This toner cartridge works with several models in the HL-1400 series, including the HL-1435, HL-1440, HL-1450 and HL-1470N.
I hope this helps.
Aug 25, 2016 | Brother HL Office Equipment & Supplies
What is the cause of problem where my printer (HL 1440) prints with black smudges & streaks of ink on the paper.
sounds like a possible problem with possibly the drum or the transfer belt. trying a different toner cartridge may fix the problem but it may not. Most likely given the cost of repair, replacement may be your best option.
thank you,
Lee
Jun 09, 2011 | Brother HL 1440 Laser Printer
I changed the Ink Cartridge a week ago but my printer is flashing the yellow toner button and will not print.
Take the toner cartridge out, give it a shake and put it back in.
How many pages did you print in the last week?
their "high yield" cartridge is only rated at 7000 pages so I am guessing the regular cartridge is rated around 3000 (or 6 reams)
It may also be complaining that the drum needs replacing depending on how long you've owned it.
Feb 24, 2011 | Brother HL 5250DN Laser Printer
Keeps saying change drum, however; a new drum was purchased and installed one week ago.
hi
most of cartridge has chip to control
if there is any chip on your cartridge change it with new one
Jun 10, 2010 | Brother HL-2070N Laser Printer
I need to install a "new drum". What's that? It's on an HL-1440 Laser Printer. How does it come apart?
The drum unit is the unit that you have been installing your toner cartridge into. It is the part you pull out of the front of you printer, remove and replace the toner cartridge into. So in other words remove the unit from your machine, remove the toner cartridge as you normally would. Now what you have left sitting there is the drum unit.
Here is a picture of the drum unit.
May 11, 2010 | Brother HL 1440 Laser Printer
Printer will not print...when I review the computer setting it states OFF LINE
Did you recently Chang the ink cartridges? Are you using factory new Brother ink cartridges instead of third party ink and cartridges or refilled cartridges?
Some companies use logic in the printer to prevent after market ink and cartridges from doing damage to the printer because of contaminated or sub-standard ink.
Don
Dec 14, 2009 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser printer-horizontal black streaks
check your drum may the corona ware is broken . change the drum.
Feb 27, 2009 | Brother HL 1440 Laser Printer
Brother hl-1440 laser printer
Did you mean 'vertical' (from top to bottom) line rather than horizontal? If it goes 'straight down,' it has to be. I think so, otherwise the added info that it is closer to the right wouldn't make sense.
This problem is normally due to contaminents on the surface of the drum itself although can also occur if a wire that discharges the excess toner from blank areas could be dirty.
Changing the drum cartridge will correct either of those problems since they are contained in the drum cartridge. If you are using 'recharged' cartridges and it only has a few copies on it, most companies will exchange it for you.
Oct 23, 2008 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
418 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
