Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Weed eater starts but won't stay running
I can get it to start when the choke is on full, but stalls and won't restart in half choke position. Please advise.
Just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Posted on Jul 27, 2010
  • Poulan Master
  • 1,631 Answers
A few things to check, then clean or replace:
  • Fuel Filter - located inside of fuel tank
  • Spark Arrestor - at muffler
  • Spark plug
  • Carburetor - new kit may be required?
Look here...
Posted on May 19, 2015
Murray weed eater won't stay running
have to go further in the carb, If you left 'todays' ethanol gas in the weed eater for more then a few months, it probably messed up the Carb. Ethanol gas is very bad for carburators on any machine
Aug 31, 2015 | Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Why won't my FeatherLite FL-20C weed eater will not stay running when I put it in full choke. What could be wrong?
    It should run ok after warming up. After starting it, let it run for a minute or so and then try gradually opening the choke. You might try increasing the throttle setting at the same time. After the motor is hot, if you have to have the throttle setting increased in order to keep it running it means the idle setting needs to be increased, usually by turning a screw to keep the fuel valve from closing so much, or that there is a problem with the fuel flow......like a clogged jet or fuel passage in the carb.
    Jul 07, 2014 | Weed Eater Featherlite Fl20 Lawn Edgers
    Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
    You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
    May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Ryobi weed eater runs at full choke, but stalls when choke is turned to run position
    does it blow out alot of blue or dark exhaust? if so adjust screw on carberator as it maybe be running rich, if this doesnt work have the switch checked for malfunctioning
    May 30, 2010 | Ryobi 15" Electric Factory Reconditioned...
    I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
    I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
    Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    My weed eater blower starts and i can run the engine at full
    See if there's a plastic adjustment/tiny little unit with standard slot,try half turn.
    Jul 18, 2009 | Poulan Garden
    31cc Ryobi weed eater engine will start, then stall shortly after
    you need to adjust the carb ,look for small screws around carb turn out 1/4 to 1/2 turn good luck
    May 24, 2009 | Black & Decker 19" Electric Lawnhog...
    Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
    2,879 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
