Question about Frigidaire 1.6 Cu. Ft. Over-the-Range Microwave
I have a frigidaire model fmotr6w it has no power, been told to change fuse? where and how do i change this fuse?
How to replace fuse in frigidaire microwave oven model fgmv174kfc
Hey friend, thanks for your post!
I understand you want to replace the fuse in your Frigidaire microwave. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Aug 19, 2014 | Frigidaire Microwave Ovens
Check fuse inside microwave oven (usually 8-10-12 A) on power supply board or main board, depending on model.
Dado
Aug 10, 2014 | Electrolux Frigidaire Gallery 30" 1.7 cu....
Where frigidaire microwave fuse located?
Good Afternoon Friend, that's a great question!
Depending on the model of your Frigidaire microwave, the fuses are typically on located behind the control console, on the magnetron or on the oven capacity. Hope this helps! - Z
Aug 03, 2014 | Frigidaire Microwave Ovens
How to change a fuse in frigidaire microwave?
Good Morning Friend,
I understand you want to know how to change a fuse in your Frigidaire microwave. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to change out the fuse with ease. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Over-the-Range Microwave
Model #PLMV169DCD Power stopped..source checked and is fine Is there an internal reset?
Almost all microwaves are internally fused (automotive style fuse with a ceramic case). They are only a couple of dollars at an appliance parts store get one with the same amp/volt rating which is stamped on the metal band at each end of the fuse. However, if the fuse blows repeatedly, it is a sign of a failing magnetron "tube" which cooks the food. Be sure to unplug unit before changing this fuse and avoid contact with the capacitor(s) inside. They can still hold a charge even when unit is unplugged.
Feb 16, 2011 | Frigidaire Microwave Ovens
My frigidaire GLMV169 manufactured in 2005 and purchased in 2006 stopped working. There is no power. The clock, buttons - everything. Tried changing the outlet and flipping fuse switch and still...
Hello there:
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Nov 19, 2010 | Frigidaire GLMV169 Microwave Oven
I do not have the manual. How do I change the poiwer level on a Frigidaire Microwave model FMT116E1W
After setting the time amount before you hit the start button, push the power button with each push it should indicate a different power level if not you've got to use the keypad, for example, 50 is 50% power etc.
Sep 07, 2009 | Frigidaire Microwave Ovens
Changed one of the door switches on my microwave now no power
check the green ground ground cable on the control panel
Aug 05, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave dead after power surge.
A) The fuse you change was the one on top just behind the control board? correct? Not the one on the door hinge side of the microwave. (as is is the Thermal cutout ) Then most likely took out the control board... i would also check the Capacitor and recifier let me know it this helped?
Aug 14, 2007 | Frigidaire PLMV169DC Microwave Oven
Frigidaire 1.6 Cu. Ft. Over-the-Range Microwave Logo
150 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
