Question about Dell 926 All-In-One InkJet Printer
I keep getting an error when trying to print Communication Not Available I tried all the solutions listed but it didn't work The printer has an error code 2200
SOURCE: My Dell 962 Photo Printer gives error when trying to photocopy.
The issue you are experiencing with your printer i.e error 2200 is related to "Scan Carrier Stall error" I believe the steps mentioned below will fix the issue,
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers .
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
I would appreciate if you could let me know if you have refilled the black cartridge, cause Dell printer often give error messages if the cartridges are refilled and not replaced with an original Dell one. If you have done so please replace the cartridge with a genuine Dell cartridge.
Regards
Malik Khan
Posted on Jan 26, 2008
  • 85 Answers
SOURCE: Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
Posted on Jul 29, 2009
john_yap
  • 51 Answers
SOURCE: printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Posted on Oct 19, 2009
  • 163 Answers
SOURCE: My Dell V305 only prints occassionally. An error
I used to have a Dell all-in-one and had same problem.
I asked Dell for new installation disc and re-installed it and that seemed to to solve the problem.
Posted on Feb 07, 2010
SOURCE: Error Message "Communication Not Available
I have a dell i810 and a HP dv6 laptop running windows 7 64. Ever since i upgraded from vista I cannot get my printer to work. The scanner works just fine however, whenever i try and print something the error "could not communicate with printer" appears and nothing prints. There is no avalible patch for this printer. Under the Devices and Printers tab on the start menu i right clicked all the printers and removed them all. I have tried reinstalling and still the problem persists.? anything else guys?
Posted on Mar 01, 2010
Have not got manual for the lexmark interpret s405, so do not understanding controls. Also the printer keeps printing cannot stop it?
You can access the User's Guide from your computer. Just click on Start > All Programs > Lexmark > View User's Guide.
If your printer keeps on printing the same document, there might be a lot of print jobs in your queue. You might have sent the same print jobs when you were getting the communication error. Just click on Start > Printers and Faxes > Double click on the Lexmark icon and clear the print jobs in the queue.
If you're frequently experiencing problems communicating with your Lexmark printer, if your printer is connected to your network, make sure that it's getting a good signal from the router. You might also want to update the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
Jul 25, 2012 | Lexmark Interpret S405 Wireless All-in-One...
"Communication Not Available" message is displayed
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
When i try to print something a window pops up that says "communication not available" ive tried restarting, unpluging the power cord and the usb cord...nothing seems to work
This problem could be caused by several factors - incorrect USB port selection, your printer is not set as your default printer, firewall, etc. This article in the Lexmark website: Communication Not Available' Error Message and Print Job Stalls in Print Queue will help you determine the cause and resolve your printing issue.
May 11, 2011 | Lexmark X2600 InkJet Printer
Communication Error
Hi there
Communication Error with the PC maybe it needs to ubinstoll the printer driver and then close down the PC and restat up again and then put back the driver, this may work.
All the best Pineworks
Apr 28, 2010 | Lexmark X3550 All-In-One Printer
Communication Error
yes may be try with diffrent cable and other usb port.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 06, 2010 | Dell 924 All-in-One InkJet Printer
Feb 07, 2010 | Dell V305w All-In-One R840635AU InkJet...
Communication error for stylus photo 2200 printer
type services.msc in command prompt you will get new window ,find print spooler services kindly stop the service and start it and close the page and restart you system and disconnect the printer,when system restarts then connect the printer ,try print some doc . also see that drivers related to printer are installed in pc by checking in device manager ,you may also try unistalling the device and reinstalling it,you will not fail this time.
thanks and regards
kindly rate this solution
Oct 28, 2009 | Epson Stylus 2200 InkJet Photo Printer
Canon MX850 keeps saying Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again. I...
It is possible that your ink cartridge is damaged. Try using an old ink cartridge that worked before and try to print again.Even if the ink cartridge you are using is full of ink, when sensitive electrical components are damaged, it wouldn't work.
You can also try using a different printer to rule out the possibility that your computer is the problem.
Sep 06, 2008 | Computers & Internet
Please open the link and follow the instructions this will definately resolve the issue, and please respond with comments to impove better service and resolution
Communication Not Available" Error When Sending a Print Job
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=true&docid=2AA10ED87ADC4C0EE040A68F5B285B98&journalid=45AF3C8CB5A7BDF9E040A68F272874F0&l=en&s=gen
Regards
Feb 04, 2008 | Dell 810 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
51 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
