Question about Dynex Wireless Optical Laptop Mouse DX-PWLMSE
My mouse does not works properly/ it works slow, cursor makes little jumps, movement not smooth. Laptop samsung R40
  • 903 Answers
Are you using it on a mousepad? If not, that is probably why you are getting jumpy and erratic movement. Put a mousepad underneath the mouse and you should see the cursor movement improve.
You can also adjust the mouse properties such as speed and control by going into the Control Panel and opening the Mouse applet.
Do you have the correct Dynex driver installed? If not, go to the Dynex website and download the driver for your mouse. Having the wrong driver (or a generic driver) can make a difference in performance sometimes.
Hope one (or all) of those solutions helps!
Posted on Jul 09, 2010
Mouse cursor jumping problem, how to fix it?
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
1.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
2.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
3.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
Aug 11, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Mouse stopped working - cursor won't react
What type of mouse do you have, the brand and the model. Sounds like you need a driver for the mouse you have. If im understanding right you have a wireless mouse?
Jan 11, 2010 | Computers & Internet
Mouse started a shakey cursor, how to fix?
If it's an optical mouse (without a ball), try using it on a smooth surface, such as a sheet of copier paper. If the cursor is jumping around even when the mouse is sitting still on your desk, junk it and get another. With optical mice sometimes selling for as little at $2, it isn't worth repairing them.
Dec 09, 2009 | Logitech Cordless Mouse
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
Eratic movement of cursor using touch pad
Sounds like you have a touchpad malfunction. If its an older laptop, I would recommend replacing it. Not worth the hassle of trying to install a new touchpad...
May 12, 2009 | Dell F3534 Touchpad
Erratic movement of cursor
try to re-install the driver of your touchpad. i suspected it could be the driver issue.
May 11, 2009 | Computers & Internet
Mouse Cursor Jumps to the right of the screen
Have you tried going into the control panel - mouse - pointer options - motion speed (slower) and experiment with pointer precision check box? Try it, see what that gets ya.
May 05, 2009 | Dynex Wireless Optical Laptop Mouse...
Jumping cursor when typing
Since you have a logitech mouse, lets just disable the touchpad. You should be able to disable the touchpad via one of these methods:
  1. Look on the top row of keys. You should have one that looks like a little mouse. If you do, hold down the "fn" key in the bottom, and press the key with the mouse on it. That *should* disable the touchpad.
  2. Go to the control panel, and find the keyboard and mouse settings. Digging through the menus, you should find a touchpad. You can disable it through there.
Steven
Sep 17, 2008 | Microsoft Windows Vista Ultimate Edition
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Jumping cursor
If you have a wireless mouse, you may need to replace the batteries inside the mouse. If it is a usb or ps2 mouse (wired), you can first try removing the ball from the bottom of the mouse and making sure you clean the rollers that are inside the mouse. Using a Q-tip works pretty good to remove all the dust buildup.
Second, you can go to the control panel, under printers and other hardware, click on Mouse, and make sure the slider isn't set on 'Fast'. Set it about half way between fast and slow for better control.
May 24, 2008 | Kensington Expert Mouse Trackball
Dynex Wireless Optical Laptop Mouse DX-PWLMSE Logo
478 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
