Question about Kenmore Refrigerators
I have a Kenmore top freezer refrigerator model # 970-605625 (Sears website says it doesn't exist) It is 3 years old. The freezer has stopped working and the fridge is on the coldest setting and is not cold enough. I have avoided calling Sears due to the fact I didn't buy an ''Extended Warranty''. Any advice on this problem would be appreciated. Thanks.
  • Margaret Jul 09, 2010
    This refrigerator is used as a second fridge. It's not opened as much as the kitchen fridge.
  • 159 Answers
SOURCE: refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Posted on Jul 12, 2007
dididsaythat
  • 291 Answers
SOURCE: freezer works fine but no cold air in refrigerator...
Check make sure evapurator fan is blowing and nothing blocking any return vents in refrigeratro side prevent air from recirclating
Posted on Dec 01, 2007
  • 65 Answers
SOURCE: Kenmore refrigerator won't cool, but freezer does.
by closing that small door you are starving the refrig of cold air . you should be getting a heavy whisper of air through that door. place all controls in the middle position, close the freezer door and check for airflow through that vent.
Posted on Feb 24, 2008
lenwest
  • 150 Answers
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
  • 3741 Answers
SOURCE: refrigerator won't get cold enough
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section . For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 27, 2010
2 year old refrigoraror stop working, interior light doesn t come on. repectalbe check and is ok.
What is the model number of your unit? From your description, sounds like your control board went out. I will need your model number to be of more help to you.
Jul 21, 2011 | Kenmore Top Freezer Refrigerator
Why would the refrigerator of my Kenmore model 253.64802400 stop being cold?
Model# 253.65812508 Serial#Ba74017239 Had a repair person from sears to check out the refrigerator he said the compressor is not working. Can you tell me if the warranty cover this item
Nov 11, 2010 | Kenmore 64802 Top Freezer Refrigerator
Side by side frig side stops working freezer still works
The best way to solve this is to email me the models number found near bottom of the fresh food compartment door. Sears problems are difficult to solve. Fixya changed their way of solving problems and posted the people to call just below your link. The email address for me is appliancepartsse@yahoo.com. I know I can solve the problem and have been here at Fixya for 3 years and have done well until now because they change the ways I can tell you how to find and fix the problem. Good Luck and hope to hear from you, Sea Breeze the model numbers for Sears look like this 213.547895
Jun 08, 2009 | Kenmore 57029 Side by Side Refrigerator
Need shelf
Sears Parts Direct
Part for KENMORE, Model # 25336608896 Shelf, sliding, wiring
Part # 218272502 Category:Refrigerators and Freezers $34.41 In stock
Apr 23, 2009 | LG LRTP1231W Top Freezer Refrigerator
Kenmore not cold enough
you'll find out some information on what it could be here...
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/51-6-631680-/new/Kenmore-Refrigerator-not-cooling-10670184001
I hope this helps you a little cuz there are a few things it could be.
Best to you.
if you have further questions please feel free to ask I'll do my best to assist.
BTW it is Model 106 70184001 for future reference.
have a good one
Jan 08, 2018 | Kenmore 93361
Freezer not working in garage top mount freezer on refrigerator
Sears is technically correct. It wouldn't work with the old coolant either. The principle is simple. The refrigerator is the same temp as your garage - it is not running. It must be in a 60 degree room to work properly. The sensor to turn it on is in the fresh food compartment, and it never calls for cooling; therefore it appears you freezer only is out - but they both work together. Hope this helps!
Feb 17, 2009 | Kenmore 64522 Top Freezer Refrigerator
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Stopped cooling
Hello cpuklutz
Welcome
You said, Kenmore; 21 cu ft; 10-years old; just stopped cooling; wondering if it even makes any financial sense to get estimate to repair, or is 10 years about it's trouble free length of service
Here is an article that you may find useful and interesting related to your situation.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thank You, HUUUM
Please remember to enter a rating before you sign off!
Sep 29, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
