Question about ViewSonic VX900 19" LCD Monitor
I have 12 volts on the PS output to the L19E CCA but I don't have schematics to troubleshoot further. the display is blank the power light is green for approsx 30 sec then turns to solid amber. Any input? Thanks julopez6@yahoo.com
  • 11,361 Answers
What is the make and model of this L19E CCA? Green to Amber can mean it does not see the video signal from the PC or it goes into shutdown mode. Pictures will help, budmrtn@aol.com
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jul 09, 2010
I am trying to figure out what battery the FP arctic cat green y6534-9665 ride on toy
12 volt.
12V Battery for Arctic Cat 650 L2170 Power Wheels Fisher Price
https://www.amazon.com/Battery-Arctic-L2170-Wheels-Fisher/dp/B01ACDHB56
Replacement For POWER WHEELS ARCTIC CAT 650 P8814 BATTERY. $109.93 ... $72.50. Replacement Battery for Fisher-Price Power Wheels 12-Volt Battery.
Amazon.com: Replacement For POWER WHEELS ARCTIC CAT 650 ...
https://www.amazon.com/Replacement...ARCTIC-BATTERY-Battery/dp/B01JGOAXS... Power Wheels 12-Volt Rechargeable Replacement Battery · 4.2 out of 5 stars ... $68.69 Prime. 12V Battery for Arctic Cat 650 P8814 Power Wheels Fisher Price.
Power Wheels L2170 Arctic Cat Replacement 12 Volt Battery Charger
https://www.amazon.com/Wheels-Arctic-Replacement-Battery-Charger/.../B01HIM3HX...
Buy Power Wheels L2170 Arctic Cat Replacement 12 Volt Battery Charger: Ride-On Toys - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Arctic Cat Batteries ' Replacement Battery for Arctic Cat ATVs
https://www.batterystuff.com/batteries/atv/arctic-cat/
Whether youre looking for a Arctic Cat or other ATV Batteries, youll find what you need at ... YTX14AHL-BS Scorpion 12v 210 CCA AGM ATV & Motorcycle Battery ... SSTX20HQ-FP Scorpion Stinger 12v 525 CCA LiFePo4 Quad Terminal ... Missing: green ‎y6534 ‎9665
Arctic Cat Batteries ' Replacement Battery for Arctic Cat Snowmobiles
https://www.batterystuff.com/batteries/snowmobile/arctic-cat/ Get replacement Arctic Cat batteries. Whether you%u2019re looking for a Arctic Cat or other Snowmobile Batteries, you%u2019ll find what you need at ... Missing: fp ‎green ‎y6534 ‎9665
Power Wheels Arctic Cat - Green ' CLG79 ' Fisher-Price
https://fisher-price.mattel.com/shop/en-us/fp/.../power-wheels-arctic-cat-green-clg79 Rating: 2.2 - ‎4 reviews - ‎US$309.99
Check out the Power Wheels Arctic Cat - Green (CLG79) at the official ... high speed lock-out; Power-Lock® Brake System; Includes 12-volt battery and charger.Missing: y6534 ‎9665
May 23, 2018 | The Toys
The problem is that the display that shows the voltage and frequency is blank. Is this something easy to repair? Can I use the generator without the display?
The generator should be ok to use with lighting and power tools and suchlike but with equipment incorporating computers and computer equipment it would be wise to get the displays fixed in order to be able to monitor the output and protect the equipment.
Not sure why the display won't work. Displays these days are essentially a low voltage device and so some sort of interface will be employed to reduce the voltage to a suitable level, unless the genny also has a 12 volt output and this is employed to drive the display. Unless you enjoy puzzles a circuit diagram will be necessary.
Jul 11, 2016 | Stanley 5000 watt, 6500 Surge Watt...
Relay clicks when applying power. Yellow light comes on. TV is dead otherwise. Power supply is outputting +5, 12, and 24 volts Mainboard (3647-0282-0150) has +5 and 12 volts always applied. Checked...
Amber light on means standby voltage is high. IF amber light does not go white when power button is pushed the its one of two things.
A. No power on command from main board. Usually labeled PS-On. Should go high from 3.3v or maybe 5volts. If not present Main is defective.
B. If the ps-on line is going high then your problem is a defective power supply.
Oct 15, 2013 | Vizio XVT472SV 47 in. HD-Ready LCD TV
Essential 800c amber power light does not power up
You need a PS, but don't take my word for it, test the Power Supply's 3 main voltages with a multimeter.
[ 3.3 Volts, 5 Volts, and 12 Volts, http://en.wikipedia.org/wiki/Computer_power_supply ]
An economical multimeter can be purchased for as little as $5 to $12.
Regards,
joecoolvette
Sep 29, 2012 | Gateway Computers & Internet
Channel Master Digital Analog Converter Box CM-7000
E1 is a 100 uF 16 VDC capacitor. I have been repairing these units lately and have experienced some of the same symptoms (LED goes red but doesn't transition to green after 30 seconds like it should). I have been able to repair some of these units. Make sure the power supply is working properly before spending significant time on the D2A board. The power supply is responsible for supplying 12, 5, and 3.3 VDC to the D2A board. A defective PS will measure 14.5 instead of 12, 6 instead of 5, and 2.9 instead of 3.3. The AC ripple should be about 5 mV on the 3.3 and the 5 volt supplies when loaded. The 12 volt can be as high as 50 mV on a good PS. The culprits are C12 (1000uf) and C10 (470 uf) which are the filter capacitors for the 3.3 and 5V outputs respectively. C12, the capacitor for the 3.3 V output is especially critical because it is used to feed the voltage regulator and overvoltage shutdown circuit. D7 is a hot part and can also fail sometimes. I have repaired 50% of my units just by changing these capacitors. I still have units where the D2A board is bad with a known good power supply. If anyone has more info on the D2A (like a schematic) please pass it along
Feb 25, 2012 | Televison & Video
VG 181 displays page then goes blank
Look to see if you do have 12~18vdc feeding the backlight inverter board (located on the left side of the monitor), it can also have blown fuses on the inverter board. Post back what you see inside so we can guide you further, this is really old monitor, 2002.
Feb 15, 2010 | ViewSonic VG181b 18.1" LCD Monitor
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Where can i get a free copy of schematic diagram for amplifier
Generally a "protect" mode would be triggered by a shorted output (speaker). I would suggest disconnection all of the speakers to see if the red light goes off.
Mar 16, 2009 | Car Audio & Video
Lights flash then powers down.
Before read this, keep in mind that this is not your model and parts are not the same. This is just to let you know the steps to take. Sorry don't have the schematic for your set, but maybe this will help in checking. I'm Ex-Army myself and Veteran of OIF and OEF.::::1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010
Aug 25, 2007 | RCA HD50LPW175 50" HDTV
ViewSonic VX900 19" LCD Monitor Logo
126 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
