When I start my computer I get a error: Error in
When I start my computer I get a error: Error in C:Windowssystem32spoolDRIVERSdLXCFtime.dll Missing entry_Run DLL @16 What can I do to fix this error?
  • 4,806 Answers
Based on the folders (spool/drivers) that sounds like the error is coming from a printer driver. Try uninstalling the last printer you installed and see if that resolves the issue.
If not, you can go into the Start Menu, under Accessories and System Tools and find the find the System Restore. When you installed the printer it should have created a Restore Point. Do a restore to that Restore Point, and it will take your systems registry and drivers back to the way they were before you did the driver update.
Once you have gotten rid of the error, by uninstalling ro restoring, then you may want to check the web site of the printer's manufacturer to see if there may be a new or corrected driver for the printer, and install that one rather than the one you used before.
Regards.
Posted on Jul 08, 2010
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
I own an ACER ASPIRE 5732Z-443G32Mn, my problem is with the webcam which is not working. When I'm trying to open the cam the following message is shown on the screen, " The program can't start...
Hi
Just reinstall your webcam driver to fix the missing DLL FILE.
Or go to this link http://www.dll-files.com/.
If still the same, the only solution is to reinstall the operating system and reinstall again the webcam driver which might be corrupted with the windows registry file.
Regards
Jul 08, 2011 | Acer Aspire 5610-4648 Notebook
I've been getting an error message: sysenv.dll missing
Hi friends,
"The file sysutil.dll is missing."
"Cannot start Metamail. A required component is missing: sysutil.dll. Please install the application again."
sysutil.dll error notifications may appear while using or installing certain programs, when Windows startup or even shutdown. sysutil.dll errors are caused by situations that lead to the removal or corruption of the sysutil.dll. In some cases, those errors could indicate mostly a registry problem, a virus or malware issue.
to Fix Sysutil.dll Errors
The sysutil.dll error message could apply to any program or system that might utilize the file on any of Microsofts operating systems including Windows XP, Windows 7, Windows Vista, and Windows 2000.
You can fix a sysutil.dll error and there are many ways to do it. A registry cleaner program can help by removing invalid sysutil.dll registry entries that might be causing the DLL error. The below utility is without a doubt the best one out there at the moment.
> Click Here http://filehippo.com/download_ccleaner/
Let me know if any further clarification is required. Hope it will help! Dont forget to rate the solution!!
Dec 21, 2010 | Acer Aspire 5500 5570-2609 Laptop
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Error in c:\program\MYWEBS~1\1.bin\M3PLUGIN.DLL Missing Entry: UPP
reinstall the MYWEBS program again, this is a driver problem which is easily sorted
regards
Dec 22, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
when start computer the error message always pop-up Error in c:\program\MYWEBS~1\1.bin\M3PLUGIN.DLL Missing Entry is there an solutions
Oct 18, 2008 | Intel Motherboard
Error code C:\Windows\system32\spool\DRIVERS\W32X86\3\LXCFtime.dll
This is part of the Lexmark printer drivers.
Try to uninstall the drivers then reinstall them.
If you don't use the LExmark printer anymore, then just uninstall.
That should correct the problem.
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
