Question about byD sign 3032 30 in. HD-Ready LCD Television
The picture on my BYD:sign 3032 has been going out, sound is OK
The picture on my 4 yr old ByD:sign 3032 has been going out but the sound remains. It happens regardless of source ie. cable box or DVD. Turning it off and then on used to fix it but now the picture only comes on for a moment and then goes black. I don't even see the outline of an image the screen in totally black. The power light shows power. Any clues as to what is wrong?
  • sawdustmaker Aug 02, 2010
    as a follow up, turning the tv off and on repeatedly seems to bring the picture back. Does this support or hinder the solution provided?
  • byD sign Master
  • 5,387 Answers
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Jul 08, 2010
Testimonial: "Thanks for the detailed explanation and diagnosis!"
  • 3 more comments
  • Cindy Wells Aug 02, 2010
    If the power cycling helps recover the image, the part that is failing has possibly a bad solder connection on the board. Most of the time, it is impossible to spot which point has to have the old solder removed and then replaced. (A magnifying glass might let you spot the problem areas but it is tough.)
    Replacing the entire board is a better option. I hope this helps.
    (When you do the power cycling, expansion and contraction changes how the solder is touching the board and the component until it fits together better.)
  • sawdustmaker Aug 09, 2010
    Thanks for addressing my additional comments. Which board would I need to replace and how much would it cost? Would it be located on the panel itself or the breakout box where all the connections go?
  • Cindy Wells Aug 09, 2010
    Since the sound remains, it is not the breakout box. The prices of inverters (which drive the backlights) range from $50 up depending on the number of backlights that are connected (6-8 is likely for a 30" TV). I'm not sure of the prices of other components. However, you need the part number off the boards in your TV to get the exact quotes. (byD:sign is not a listed manufacturer at shopjimmy.com . They may get their TVs manufactured by another company with a change of nameplate.)
    I wish that I could be of more help. However, I'd need to see the labels on the different boards to get the quotes. The labels are usually very clear black type on white labels so they are easy to find.
  • sawdustmaker Nov 23, 2010
    I took out the back light inverter and had it checked by a local shop. It was ok. There was mention made that since the sound remains it could be the dc power supply as opposed to the ac power supply. Any thoughts would by greatly appreciated.
  • Cindy Wells Nov 23, 2010
    "I took out the back light inverter and had it checked by a local shop. It was ok. There was mention made that since the sound remains it could be the dc power supply as opposed to the ac power supply. Any thoughts would by greatly appreciated. "
    Most monitors only have one power supply and then you have the AC/DC inverter. It is possible that one branch (or wire) from the power supply to the boards has failed. Think of a desktop power supply - some have multiple rails so that the power can be balanced to the various components. Even the ones that only have one rail can have a problem with say the 3.3V side.
    Unfortunately, I've never seen only one part of a monitor power supply fail. I'm not even sure what voltage you'd expect at each cable from the power supply to test this premise. This exceeds my trouble-shooting skills.
I want to sign in as ben parry
sorry but we have no idea where you want to sing i . certain it is not to a TV
Oct 06, 2016 | byD sign 3032 30 in. HD-Ready LCD...
What can I do with a malfunctioning by Dsign TV and where can I have it fixed?
I am assuming this is the board you need... I would take the old one out and see if it is the same part # first! Byd 40 4032 782 L40D11 6900 Terminal Board Unit
May 24, 2016 | byD sign Televison & Video
I need a power cord for a BYD LCD tv model D:3032
Power cords can be bought from most of the electronics spare part selling shops at your town. There is no special attention to choose one. Select a good quality power cord from a reputed brand. that is all.
Jul 03, 2012 | byD sign 3032 30 in. HD-Ready LCD...
I have Power, but no picture or sound
is there a screen saver that appears or a No signal popup?
check the connections from the source. maybe remove the source cable and look to see if the no signal screen appears...
if not maybe some damage has occurred.
May 18, 2009 | byD sign 3032 30 in. HD-Ready LCD...
Power supply for byD:sign 3032
I have a new OEM power supply for this tv.
If intertested, please email me your contact info.
Thanks,
Art
Aug 25, 2008 | byD sign 3032 30 in. HD-Ready LCD...
Peascorn
I have a New OEM power supply for a byDesign 3032 TV.
If interested, please email me your contact info.
Thanks,
Art
Jul 17, 2008 | byD sign 3032 30 in. HD-Ready LCD...
Power Adapter
I NEED a new power adapter ttttttttttoo.. can you HELP please,, I allready had a so called TV repaire Man try to fix it he said he cant get a new power adapter for it to be fixed .... I stupidly PAYED him waited 9 months later, and still no TV fixed..Im taking him to smalls claimes court.....Very un happy persone ,I just want a new power adapter,....please some one out there...peascorn...I have d:sign TV 3032- ad-13d-2...
May 25, 2008 | byD sign 3032 30 in. HD-Ready LCD...
No picture
btw for anyone experiencing these problems with the infamous "is-lcdtv32" byd:sign is the same manufacuterer as insignia, its the same company with a different sticker. i know this isnt a solution, but parts for all discontinued insignia';s can be purchased thru byd:sigh(by design). hope this helps .
Oct 06, 2007 | byD sign d:4232 42 in. HD-Ready Plasma...
byD sign 3032 30 in. HD-Ready LCD Television Logo
252 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
