Question about GE DWSR483GB Gas Dryer
My ge dryer wont heat up
My GE dryer igniter lights up but wont kick out a flame, there is no heat my clothes wont dry???
Model: DWSR483GBOWW
  • GE Master
  • 43,501 Answers
Hi, If you have a gas dryermy ge dryer wont heat up - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...my ge dryer wont heat up - 2_bing.gif/>Dryer2_bing.gif Troubleshooting Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
GE Profile Harmony Gas Dryer not heating/drying clothes.
let me ask you this does the ignitor glow orange but no flame when you have no heat?usually on a gas dryer if at first you have heat and then after 10 to 30 minutes no heat it's usually the gas coils located on top of the gas valve,common problem,after the coils cool down they will work again,that dryer is kind of complicated to work on seeing how it does have two motors in it but you should be able to get at the gas coils,if you send the model number i can look it up for you.but it sounds like you have bad gas coils,the only way to tell is run the dryer,when the heat stops working look at the ignitor,if it glows orange and the flame doesn't ignite you have bad gas coils.
Feb 14, 2014 | GE Profile Harmony DPGT750GC Gas Dryer
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
GE gas dryer heats but doesnt fry
if the flame is lighting but the clothes don't dry you have a blocked vent line or lint blocked up in the dryer and needs to be cleaned out.
The Dryer is Dead. It will not make a sound when the start button is pushed
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or OK like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
Be careful in using laundry products not to spill them on the exterior surface of any washer or dryer. Wipe up any spills promptly with a damp soft cloth or paper towel. Most exteriors are painted synthetic enamel, which can be damaged or removed by chlorine bleach, ammonia, solvents or other chemicals often used in laundering and stain removal. Do not use dryer top as a work-top for stain removal unless it is protected by a heavy plastic cover, or for rust removal. Use the sink instead and follow remover product label directions exactly, including flushing the sink with cold water.
Do not spray per-wash stain removers on clothing on top of the dryer unless the top is protected completely; this may corrode plastic control parts as well as paint.
Clean lint filter after each load for efficient drying. If the load is loaded with lint, clean the filter part-way through the drying cycle also. Clean out the exhaust vent system at least once a year, and be sure it is not clogged at any time. NEVER vent a dryer into the house; vent to the outside
If crayon gets into the dryer and melts onto the drum, remove as much as possible with non-flammable household cleaner. (READ LABEL TO BE SURE.) A flammable cleaner could cause a fire in the dryer. Apply cleaner to a sponge or cloth and the wipe interior. Do NOT spray or pour on the interior; it might get down inside the dryer. Wipe off with rags or paper towels. Then tumble old rags to remove any residue left, until no more comes off. A colored stain may remain on the drum.
If a drum is spotted by starched or tinted articles, wipe the interior with a cloth moistened with a diluted bleach solution. Use a sponge or clean cloth, dipped in suds, to remove the bleach solution from the drum. Rinse well and dry.
If the dryer is used to dry laundered clothing, such as children snow pants between outings, wipe the drum with suds and rinse. This will remove any dirt before clean laundry is placed into the machine.
Wipe the door opening occasionally. Clean the exterior with suds and rinse. To protect the finish, polish with an appliance wax.
A case of white clothes coming out of a dryer blue: New jeans had been washed and then dried in that dryer just before. Sometimes dye will come off new blue jeans and dry on the inside of the dryer drum, and then transfer to the next batch of wet clothes put inside. It's good to check the dryer drum after a load of brand new jeans. If it is dye coated, clean the inside with soapy water until no color comes off on the cleaning cloth. Wipe off all soapy residue with a clean wet cloth.
Check with your state or city to see if you need a permit to work on your gas dryer before doing any repairs. The first thing you need to do when your GE-HP gas dryer is not heating, is to check to see if your dryer ignite is glowing or not.
please comment on these solution by staying now helpful
If the ignite glows, the problem could be the gas valve, the coils or the gas supply to the dryer.
If the ignite doesn't glow, then you need to check the following parts.
The igniter:
The igniter is a resistor made of ceramic and other materials that will get red hot when electricity passes through it.
The job of the igniter is to open the contacts on the flame sensor and ignite the gas. A bad igniter could be the reason why your GE-HP gas dryer is not heating.
The flame sensor:
The flame sensor is located on the combustion chamber, the job of the flame sensor is to open the gas valve and shut off the igniter. A bad flame sensor will cause the dryer not to heat.
The timer:
The timer is a distribution center where the electricity is directed to the different electric parts in the dryer.
The mayor problem you will find inside of the timer are burnt contacts.
When the contacts are burnt, there is no way for the electricity to reach the intended parts. Contact B & A have to be close in order for the electricity to travel to the temperature switch.
The temperature switch:
This switch is another distribution control. It take electricity from the timer and send it to the selected parts on the thermostats. If your GE-HP dryer is not heating, this is one of the parts you need to check.
The thermostats:
There are three different thermostats in most dryers. From the temperature switch electricity has to pass trough the safety thermo left, the drum outlet thermostat, the control inlet thermostat, and to the heating elements.
A bad thermostat could be the reason why your GE-HP gas dryer is not heating.
The motor switch:
The motor switch has two contacts that allows the heating elements to be turned on, only when the motor is running..
Dec 21, 2010 | General Electric DBSR463GGWW Gas Dryer
My ge dryer ( model # dde5900ral ) does not always provide heat during the drying process in the regular drying modes. I have found that I can place the dial to timed dry between the 90 & 120 minutes...
Hi
1.Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2.Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3.Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4.Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5.Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps... Please post back if you need more information.
Daniel
Nov 08, 2010 | GE Dryers
I have a GE gas dryer model DBXR463GD1WW, the problem is that it star the flame but dont heat enough for dry the cloth I change the sensor in the flame but it still have the same problem
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 03, 2010 | GE DBXR463GB Gas Dryer
GE Dryer has not heat
dryer spins fine but wont heat
Aug 05, 2009 | GE Dryers
GE DWSR483GB Gas Dryer Logo
562 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
